Is there any chance of Rares turning these into HJ, HX fascia's by removing the RTS raised section on the left side? That is the only thing stopping me from buying a repro fascia for my HX Sandman. Also do Rares make the radio blank off for these?
Forum Rank:: Member
It is not possible for us to remove the raised section successfully although I do know it has been done. We do not make the blanking plate for the dash
Hi Les, I didnt mean physically grinding it off. I was thinking it may not be too costly to have the mold modified by infilling the raised RTS section and whether Rares would consider doing it as there are a lot more HJ/HX Monaros and Sandmans than there are HZs.
Forum Rank:: Member
It maybe possible to put an insert in the tooling I will ask the question
also with the gts dahses the warning lenses are very wrong. dont look anything like originals. this might be something else worth looking at?
cheers jason |
Forum Rank:: Member
They are original we brought all the old stock from Nylex before the closed, they used to make the fascias for GMH, what is wrong with them?
i will send you a pic les. the warning lenses are nothing like the original hj-wb ones. hj is diferent to hz also but not much. (apart from the blue warning lense for the headlights). anyhow ill grab some pics and emails you all the diferances.
cheers jason |
Ive just recently purchased a HJ Sandman and was wondering if anything ever happened about doing a repro HJ HX GTS dash facia??
Forum Rank:: Member
No only HZ is available at the moment
Thanks Les, Ill put my hand up for one or two straight away if you decide to go with it.....and I dont think Ill be standing in line by myself. The only way to get one, so it seems, is on ebay (or similar) and all of them, bar none, have butchered radio holes. Surely they would be more popular than the HZ ones given it covers two models.......wouldnt it?
...and dash pads for HJ X Z.....gotta be a market there youd reckon.
Forum Rank:: Member
There defiantly is a market for Crash pads for all models we are trying to make a simple one first the LJ one but we are not doing to well , if we can make it then we will move on to others
Les ...was I dreamin or did I see HJ X Z front interior door trims on the RS site a few months ago?????? Do you still do them?
Forum Rank:: Member
It is over 12 months since we had door trims but that may change in the next 3-4 months
