Is the automatic transmission in a VR V8 (GM 308 engine)interchangeable with a VT V8 (GM 308 engine)? |
In thrust we trust |
Hi Taz2.
No, the VR boxes (both the 4 & 5 prefix type) have a different solenoid set-up.
Only the VS onwards boxes (6 prefix & later) will work properly with the VT ECU.
The trans itself is basically the same, it's the valve body, wiring harness |
Thanks for the info Terry. |
why would you want a VR one? do you have a spare?
VN Calais, V8 Auto, Blown etc etc.
Air con, Electrical, Car audio Master.
Actually i asked the question backwards, but the answer still applies. We sold a VR auto transmission to a customer to go in a VR, but he claims the transmission is faulty. We are prepared to exchange it, but don't have a VR one in stock. The boss was |
Hi Taz2.
You should have asked that question first up.
This is a common problem because the 4 prefix & 5 prefix boxes (both in VR) are NOT interchangable. The mem-cal in the ECU is different. If you swap an auto in a VR, make sure you use the mem-ca |
