Taz2 Offline
#1 Posted : Friday, 14 October 2005 3:40:27 AM(UTC)
Taz2
Is the automatic transmission in a VR V8 (GM 308 engine)interchangeable with a VT V8 (GM 308 engine)?
In thrust we trust
#2 Posted : Friday, 14 October 2005 4:12:56 AM(UTC)
Hi Taz2.
No, the VR boxes (both the 4 & 5 prefix type) have a different solenoid set-up.
Only the VS onwards boxes (6 prefix & later) will work properly with the VT ECU.
The trans itself is basically the same, it's the valve body, wiring harness
Taz2 Offline
#3 Posted : Saturday, 15 October 2005 4:02:14 PM(UTC)
Taz2
Thanks for the info Terry.
In thrust we trust
#4 Posted : Sunday, 16 October 2005 1:32:55 AM(UTC)
why would you want a VR one?
do you have a spare?
VN Calais, V8 Auto, Blown etc etc.
Air con, Electrical, Car audio Master.
Taz2 Offline
#5 Posted : Sunday, 16 October 2005 3:47:03 PM(UTC)
Taz2
Actually i asked the question backwards, but the answer still applies.
We sold a VR auto transmission to a customer to go in a VR, but he claims the transmission is faulty.
We are prepared to exchange it, but don't have a VR one in stock.
The boss was
In thrust we trust
#6 Posted : Sunday, 16 October 2005 6:50:14 PM(UTC)
Hi Taz2.
You should have asked that question first up.
This is a common problem because the 4 prefix & 5 prefix boxes (both in VR) are NOT interchangable. The mem-cal in the ECU is different. If you swap an auto in a VR, make sure you use the mem-ca
