Fastlane
Holden Forums
Holden General Discussion
Block stud pattern change from trimatic to turbo
Just wondering if anyone knows of any machine shops/mechanics/trans joints in adelaide that does block pattern changes for gear boxes as i want to change the stud pattern of my black 308 from trimatic to turbo set-up. Also is there anywhere that can do it while the engine is in the car or would it have to be removed, because i have heard it is possible to do it with engine still in car. Cheers Chopper Edited by user Tuesday, 9 March 2010 9:57:01 AM(UTC)
| Reason: Not specified |
1970 HG Panelvan 1971 HQ 1 Tonner 2001 WH Statesman Kawazaki KLX250SF |
Thanks: 1 times Was thanked: 618 time(s) in 584 post(s)
I think you mean trimatic to TH pattern!
I dont think it can be done in the car. From memory it has to be a bare block too.
Byrons right , not done in the car ,bare block,and trimatic to turbo,get another block its easier.salibury pattern is your diff....?
Jim in Adelaide...Hindsight is bad vision! |
Jim in Adelaide.. |
Cheers HK1837, i did mean traumatic to turbo, got too many things on my mind. Will be running a 9" diff, possibly 3.5s, dont think the trimatic will hold up after a few skids.
**CHOPP3R** 71 HQ TONNER 01 WH STATESMAN |
Joined: 3/08/2007(UTC) Views messages in topic : 1,902
CRS do an adaptor from Tri to TH and vice versa i believe.
WANTED: -2 14 x 9.25 CSA style Centrelines. -2 x 15 x 8 Dragway centrelines |
Yeah, ive checked out adaptors, dont think im too keen to use one though, would rather just change the block stud pattern or get a turbo pattern block. I have read a bit about adaptors and it seems to me that its jus as much of a stuff around to fit them etc as it would be to just get the stud pattern changed.
Id be keen to hear from anyone that is using these adaptors and what there opinion is. (TH400 box to Trimatic engine block)
I had one in a HJ Statesman and it busted the torque converter bolts when towing. Just get a VN-VSIII 304 block and use it. ALl the 308 stuff will fit on.
Thanks: 7 times Was thanked: 15 time(s) in 13 post(s)
i had a t400 on a tri block, the bellhousing on the turbo box was cut and shut to suit the block and it was fine. Much simpler, probably cheaper, and the the trans doesnt need stripping to do the job. edit: i wouldnt use an adapter unless i was going to pull the convertor and have it altered to suit the 5/8" extra clearance. 11.38@117 Edited by user Tuesday, 9 March 2010 7:10:36 PM(UTC)
ive never used a adaptor but i know someone who did and while giving the car a hard time it cracked
dont use adaptors.ever..(except for holleys)lol
Jim in Adelaide.. |
Why not get ur tri fixed properly , with a bit of work they can handle up to 800 BHP + ,trust me!
< Gotta Luv It! |
 <b><font color="orange">< 4 SALE , SELLING .......SOLD!</b></font id="orange"> |
good advice Itch,probably spend more than that to redrill block/rebuild turbo trans.
Jim in Adelaide.. |
quote: Originally posted by ITCH
trust me!
< Gotta Luv It!
hahahahahahahaha, "trust me" said the sailor to the hooker..lol "Reputations are made and broken as soon as you enter or leave my shed.."
Stop wreckin every fing WRECKED !! CHEERS!
< Gotta Luv It! |
TRUST ME, im not!!!
ring this bloke: Burpengary Transmissions Contact: John Elsom Address: 21 Reynolds Court, Burpengary, QLD, 4505. Phone: (07) 3888 5172 CHEERS!!
< Gotta Luv It! |
ring this bloke:
CHEERS!!
< Gotta Luv It!
but i dunn want a tranz built or a block drilled... ohh its for the original poster of this thread CHEERS ITCHY!!!!!!! you da block drillin recommendation man "Reputations are made and broken as soon as you enter or leave my shed.."
John @ Burpengary Transmissions built me a Trimatic about 6 years ago , I had it in my SLR L32 with a blown 355 ,ran 10.56 big wheels 9inch, farkin awesome box!! big job doing all that redrillin sh!t , tail shaft , cross-member shifter etc etc. to OP just give John a ring and he will put ya onto someone down your way that will do it for ya! CHEERS !!
< Gotta Luv It! |
[email protected], must have been happy track, or 1000ft only that day itchy.hahah CHEERS!! "Reputations are made and broken as soon as you enter or leave my shed.."
TRUST ME WRECKED!! CHEERS!
< Gotta Luv It! |
Fastlane
Holden Forums
