stephenreed Offline
#1 Posted : Tuesday, 9 March 2010 9:28:57 AM(UTC)
stephenreed
Just wondering if anyone knows of any machine shops/mechanics/trans joints in adelaide that does block pattern changes for gear boxes as i want to change the stud pattern of my black 308 from trimatic to turbo set-up. Also is there anywhere that can do it while the engine is in the car or would it have to be removed, because i have heard it is possible to do it with engine still in car.
Chopper
Edited by user Tuesday, 9 March 2010 9:57:01 AM(UTC)  | Reason: Not specified
1970 HG Panelvan
1971 HQ 1 Tonner
2001 WH Statesman
Kawazaki KLX250SF
#2 Posted : Tuesday, 9 March 2010 9:41:51 AM(UTC)
Was thanked: 618 time(s) in 584 post(s)
I think you mean trimatic to TH pattern!
I dont think it can be done in the car. From memory it has to be a bare block too.
#3 Posted : Tuesday, 9 March 2010 9:46:21 AM(UTC)
Byrons right , not done in the car ,bare block,and trimatic to turbo,get another block its easier.salibury pattern is your diff....?
stephenreed Offline
#4 Posted : Tuesday, 9 March 2010 9:54:21 AM(UTC)
stephenreed
Cheers HK1837, i did mean traumatic to turbo, got too many things on my mind. Will be running a 9" diff, possibly 3.5s, dont think the trimatic will hold up after a few skids.
**CHOPP3R**
71 HQ TONNER
01 WH STATESMAN
1970 HG Panelvan
1971 HQ 1 Tonner
2001 WH Statesman
Kawazaki KLX250SF
adam PERTH Offline
#5 Posted : Tuesday, 9 March 2010 11:08:42 AM(UTC)
adam PERTH
CRS do an adaptor from Tri to TH and vice versa i believe.
WANTED:
-2 14 x 9.25 CSA style Centrelines.
-2 x 15 x 8 Dragway centrelines
stephenreed Offline
#6 Posted : Tuesday, 9 March 2010 11:50:39 AM(UTC)
stephenreed
Yeah, ive checked out adaptors, dont think im too keen to use one though, would rather just change the block stud pattern or get a turbo pattern block. I have read a bit about adaptors and it seems to me that its jus as much of a stuff around to fit them etc as it would be to just get the stud pattern changed.
Id be keen to hear from anyone that is using these adaptors and what there opinion is. (TH400 box to Trimatic engine block)
**CHOPP3R**
71 HQ TONNER
01 WH STATESMAN
1970 HG Panelvan
1971 HQ 1 Tonner
2001 WH Statesman
Kawazaki KLX250SF
#7 Posted : Tuesday, 9 March 2010 5:40:14 PM(UTC)
I had one in a HJ Statesman and it busted the torque converter bolts when towing. Just get a VN-VSIII 304 block and use it. ALl the 308 stuff will fit on.
greenhj Offline
#8 Posted : Tuesday, 9 March 2010 7:08:08 PM(UTC)
greenhj
Was thanked: 15 time(s) in 13 post(s)
i had a t400 on a tri block, the bellhousing on the turbo box was cut and shut to suit the block and it was fine.
Much simpler, probably cheaper, and the the trans doesnt need stripping to do the job.
edit: i wouldnt use an adapter unless i was going to pull the convertor and have it altered to suit the 5/8" extra clearance.
11.38@117
Edited by user Tuesday, 9 March 2010 7:10:36 PM(UTC)  | Reason: Not specified
#9 Posted : Wednesday, 10 March 2010 4:30:28 AM(UTC)
ive never used a adaptor but i know someone who did and while giving the car a hard time it cracked
#10 Posted : Thursday, 11 March 2010 3:15:47 AM(UTC)
dont use adaptors.ever..(except for holleys)lol
ITCH Offline
#11 Posted : Friday, 12 March 2010 5:48:36 AM(UTC)
ITCH
Why not get ur tri fixed properly , with a bit of work they can handle up to 800 BHP + ,trust me!
< Gotta Luv It!
<b><font color="orange">&lt; 4 SALE , SELLING .......SOLD!</b></font id="orange">
#12 Posted : Friday, 12 March 2010 6:44:58 AM(UTC)
good advice Itch,probably spend more than that to redrill block/rebuild turbo trans.
#13 Posted : Friday, 12 March 2010 7:13:39 AM(UTC)
Originally posted by ITCH
trust me!
< Gotta Luv It!
hahahahahahahaha, "trust me" said the sailor to the hooker..lol
ITCH Offline
#14 Posted : Sunday, 14 March 2010 2:52:25 AM(UTC)
ITCH
Stop wreckin every fing WRECKED !!
CHEERS!
< Gotta Luv It!
#15 Posted : Sunday, 14 March 2010 3:05:53 AM(UTC)
TRUST ME, im not!!!
ITCH Offline
#16 Posted : Sunday, 14 March 2010 3:15:07 AM(UTC)
ITCH
ring this bloke:
Burpengary Transmissions
Contact: John Elsom
Address: 21 Reynolds Court, Burpengary, QLD, 4505.
Phone: (07) 3888 5172
CHEERS!!
< Gotta Luv It!
#17 Posted : Sunday, 14 March 2010 3:28:51 AM(UTC)
ring this bloke:
Contact: John Elsom
CHEERS!!
< Gotta Luv It!
but i dunn want a tranz built or a block drilled...
ohh its for the original poster of this thread
CHEERS ITCHY!!!!!!! you da block drillin recommendation man
ITCH Offline
#18 Posted : Sunday, 14 March 2010 3:59:02 AM(UTC)
ITCH
John @ Burpengary Transmissions built me a Trimatic about 6 years ago , I had it in my SLR L32 with a blown 355 ,ran 10.56 big wheels 9inch, farkin awesome box!! big job doing all that redrillin sh!t , tail shaft , cross-member shifter etc etc.
to OP just give John a ring and he will put ya onto someone down your way that will do it for ya!
CHEERS !!
< Gotta Luv It!
#19 Posted : Sunday, 14 March 2010 4:26:05 AM(UTC)
[email protected], must have been happy track, or 1000ft only that day itchy.hahah
CHEERS!!
ITCH Offline
#20 Posted : Sunday, 14 March 2010 5:46:48 AM(UTC)
ITCH
TRUST ME WRECKED!!
CHEERS!
< Gotta Luv It!
