witcheshollow racing team Offline
#1 Posted : Tuesday, 22 November 2005 8:54:13 AM(UTC)
Just picked up an LC that has still got the original drums on the front and was wondering about options for a disc brake front end. Appart fron the original solid disc can you use the vented disc and caliper set up from an LH/X ? and is there a differance in the stub axels at all or are the drum stubs the same as disc ? I know the wheel cylinders need to be changed in the rear as does the Master cylinder is the any thing else to be changed ? Any other brake option ? Also how hard is it to fit a stearing colum from a commodore it it? All sugestions and pointers welcome.
When the green flag drops the bulls@#t stops!!
"Such is life"
#2 Posted : Tuesday, 22 November 2005 7:10:07 PM(UTC)
Disc and drum stubs are different as the drum stub has no caliper mount. LH/LX/UC/VC/VH discs aren't vented except for the L34 and A9X which are HQ pattern anyway (VC-VH 4cyl are the same disc as LH-UC). Why don't you copy the XU-1 and use HG discs and ca
Edited by user Wednesday, 23 November 2005 3:45:42 AM(UTC)  | Reason: Not specified
peter_flane Offline
#3 Posted : Tuesday, 22 November 2005 10:33:35 PM(UTC)
peter_flane
Read this
http://www.oldholden.com...dex.php/Hopper_Stoppers
and this
http://www.oldholden.com.../index.php/Brake_Basics
Should give you some more ideas and info. We will test you at the end of it all. lol
#4 Posted : Thursday, 24 November 2005 8:24:43 AM(UTC)
OK Byron I like your idea but the stub axels still are a little unclear, as they need replacing to accomodate the caliper can I use the stub axels from either the HG of LH/X torana or do I have to track down LC/J stubs? Ow and can the brake boster be used
"Such is life"
#5 Posted : Thursday, 24 November 2005 7:27:43 PM(UTC)
The LJ XU-1 booster is the same thing as a HT-HG one. Not sure if the operating rod is the same, but the casing is. Find an XU-1 and have a look at how it mounts.
As for stubs, the LJ disc brake stubs list as a different part number to the LH/LX ones f
peter_flane Offline
#6 Posted : Friday, 25 November 2005 8:02:23 AM(UTC)
peter_flane
If the LC LJ drum stubs are the same as LH, then I would recomment you use LH -UC disc brake setup. I know that us EH guys cant use Torana stubs due to different 'kingpin inclination angle' so it would be advisable that you do use Torans disc stubs to kee
#7 Posted : Friday, 25 November 2005 5:59:41 PM(UTC)
Yes thanks Peter the hopper stopper info was great, just tossing some ideas around as I have 1 LH front end and 1 UC front end siting in the yard at the moment and a complere LH, plus a HG. I have owned 5 LJ's but 3 were GTR'S and 2 XU-1's all of which I
"Such is life"
#8 Posted : Sunday, 27 November 2005 5:51:03 PM(UTC)
I not too long ago i sold my XU-1 Torana. I went to the local brake place to get LH front brakes fitted. i was told not to do it. LH are a bigger pad and thicker disc but only single piston. the XU-1 has 2 pistons. After staying with the standard brake wh
gtr235 Offline
#9 Posted : Tuesday, 29 November 2005 4:17:53 AM(UTC)
gtr235
I have VL commodore disks on My LC GTR. They are from an ex Police pursuit v8 vl. I just used a CRS kit. Mailed them torana drum brake stub axles which they machined and sent back with a bracket to attach the calipers. The kit fits perfectly other than
#10 Posted : Friday, 9 December 2005 5:33:15 AM(UTC)
There an article in ( Building a tougher Holden A Technical Guide no 2 ) that has a step by step giude with photo's and instruction about fitting LH disks to LC/J Torana.
They have a list of parts and costing ( Costing is out of date ).
There also an
