Fastlane
Holden Forums
Holden General Discussion
LC Torana drums to disc's options please.
Just picked up an LC that has still got the original drums on the front and was wondering about options for a disc brake front end. Appart fron the original solid disc can you use the vented disc and caliper set up from an LH/X ? and is there a differance in the stub axels at all or are the drum stubs the same as disc ? I know the wheel cylinders need to be changed in the rear as does the Master cylinder is the any thing else to be changed ? Any other brake option ? Also how hard is it to fit a stearing colum from a commodore it it? All sugestions and pointers welcome.
When the green flag drops the bulls@#t stops!! |
"Such is life" |
Thanks: 1 times Was thanked: 636 time(s) in 598 post(s)
Disc and drum stubs are different as the drum stub has no caliper mount. LH/LX/UC/VC/VH discs aren't vented except for the L34 and A9X which are HQ pattern anyway (VC-VH 4cyl are the same disc as LH-UC). Why don't you copy the XU-1 and use HG discs and ca Edited by user Wednesday, 23 November 2005 3:45:42 AM(UTC)
| Reason: Not specified |
Read this http://www.oldholden.com...dex.php/Hopper_Stoppers
and this http://www.oldholden.com.../index.php/Brake_Basics
Should give you some more ideas and info. We will test you at the end of it all. lol |
OK Byron I like your idea but the stub axels still are a little unclear, as they need replacing to accomodate the caliper can I use the stub axels from either the HG of LH/X torana or do I have to track down LC/J stubs? Ow and can the brake boster be used |
"Such is life" |
The LJ XU-1 booster is the same thing as a HT-HG one. Not sure if the operating rod is the same, but the casing is. Find an XU-1 and have a look at how it mounts.
As for stubs, the LJ disc brake stubs list as a different part number to the LH/LX ones f |
If the LC LJ drum stubs are the same as LH, then I would recomment you use LH -UC disc brake setup. I know that us EH guys cant use Torana stubs due to different 'kingpin inclination angle' so it would be advisable that you do use Torans disc stubs to kee |
Yes thanks Peter the hopper stopper info was great, just tossing some ideas around as I have 1 LH front end and 1 UC front end siting in the yard at the moment and a complere LH, plus a HG. I have owned 5 LJ's but 3 were GTR'S and 2 XU-1's all of which I |
"Such is life" |
I not too long ago i sold my XU-1 Torana. I went to the local brake place to get LH front brakes fitted. i was told not to do it. LH are a bigger pad and thicker disc but only single piston. the XU-1 has 2 pistons. After staying with the standard brake wh
I have VL commodore disks on My LC GTR. They are from an ex Police pursuit v8 vl. I just used a CRS kit. Mailed them torana drum brake stub axles which they machined and sent back with a bracket to attach the calipers. The kit fits perfectly other than
There an article in ( Building a tougher Holden A Technical Guide no 2 ) that has a step by step giude with photo's and instruction about fitting LH disks to LC/J Torana. They have a list of parts and costing ( Costing is out of date ).
There also an
Fastlane
Holden Forums
