HK350_2233 Offline
#1 Posted : Tuesday, 17 August 2010 4:55:37 AM(UTC)
HK350_2233
Any one here know how the studs on the front of a bonnet are put on from factory. Rare spares have that kit but use rivets, wouldn't that leave a lump on the inside?
DCOE Offline
#2 Posted : Tuesday, 17 August 2010 4:57:16 AM(UTC)
DCOE
welded (resistance)
HK350_2233 Offline
#3 Posted : Tuesday, 17 August 2010 5:05:18 AM(UTC)
HK350_2233
Wouldn't be able to do this anymore, Unless you had new studs ?
80569K Offline
#4 Posted : Tuesday, 17 August 2010 5:19:12 AM(UTC)
80569K
Well then, theres an opening for a repro item.
Panel beaters ain't too fond of those studs in the prep stages, but wish they were there in the fit up stage, lol.
petaus Offline
#5 Posted : Tuesday, 17 August 2010 6:16:08 AM(UTC)
petaus
you can still get them, they panel shop that have a electric dent puller to weld the puller on can weld the little studs on, but the problem lie in lining them all up or the mould wont fit, i guess they had a jigg of some sort in the factory, also im told with thicker to pack paint once painted you cant get the clip on??
pete.
petaus Offline
#6 Posted : Tuesday, 17 August 2010 6:17:14 AM(UTC)
petaus
look on flee bay for electric dent puller
hazzard county Offline
#7 Posted : Tuesday, 17 August 2010 6:21:47 AM(UTC)
hazzard county
they call them slide hammer studs
slake Offline
#8 Posted : Tuesday, 17 August 2010 6:45:44 AM(UTC)
slake
Mate yes you can still get them , most panel shops i have worked in have had them, and the fittings for them on their spot welders using the single sided spot. Most auto paint suppliers , wurth ,can also supply the pins. Spotting them on an even level you could use a steel engineering ruler taped as not to conduct the weld current clamped to the leading bonnet edge. This would eliminate the rivet protruding inside the bonnet edge problem.
HK350_2233 Offline
#9 Posted : Tuesday, 17 August 2010 4:14:10 PM(UTC)
HK350_2233
Thanks for all your help. Got a NOS hk standard bonnet but dose'nt have the studs on it. Do not want to wreck by useing rare spares kit.
