Big Al Offline
#1 Posted : Monday, 23 August 2010 7:50:56 PM(UTC)
Big Al
Ordering all my suspension bits shortly, and I'm just after some advice for how low I should go on my HQ V8 Premier sedan.
I intend on using the car fairly regularly so I don't want it in the weeds, just a nice stance that isn't going to bottom out on every kerb and speed hump. Won't be using any bigger than 15" wheels.
If you can, post a photo with how much you've lowered it.
Cheers, Big Al
bullitljv8 Offline
#2 Posted : Tuesday, 24 August 2010 2:34:32 AM(UTC)
bullitljv8
2 inches
#3 Posted : Tuesday, 24 August 2010 3:24:37 AM(UTC)
Thats about right.Same as my van.
Jim in Adelaide...DONT LISTEN TO BULLS@#T LONGER THAN YOU HAVE TOO!
Big Al Offline
#4 Posted : Tuesday, 24 August 2010 7:06:16 PM(UTC)
Big Al
Too easy. Thanks for that
#5 Posted : Wednesday, 25 August 2010 2:22:02 AM(UTC)
legally in SA its 32mm to the bump stop, Hj -HZ was 36mm.
bullitljv8 Offline
#6 Posted : Wednesday, 25 August 2010 5:34:57 AM(UTC)
bullitljv8
yeah nothing better than watching a cop get on his knees and under the car to measure the bump stop ROTFLMAO half of them dont even know what bump stop is!!
Big Al Offline
#7 Posted : Wednesday, 25 August 2010 5:53:49 AM(UTC)
Big Al
Hehe, I think in WA, its just 100mm to the lowest part of the car. In any which case, I'm going for 2" lower so hopefully cops will only be pulling me over for high 5's.....
bogart69 Offline
#8 Posted : Wednesday, 25 August 2010 6:16:22 AM(UTC)
bogart69
From memorie after 27 yellow stickers on mine I think it was 600 mm to the centre of the headlight in W.A., but it was a while ago.
If you see rubbish put a circle around it.(FORD)
#9 Posted : Thursday, 26 August 2010 11:32:53 PM(UTC)
I went to Pedders and asked for a set of springs for my HQ and I told him I wanted it to sit illegaly low.
I bought a set of Pedder SportsRyder 2062 and a set of 2060 and I think they are the standard ones for the racing HQ's ?? Not sure.
Never had a problem bottoming out because I've always had heavy SportsRyder shocks under it.
Soft shocks might bottom out more often though.
The rear springs can slip out if you jack the car up.
This is what it looks like with 15" Pontiac rims.
"I would never want to be a member of a group whose symbol was a guy nailed to two pieces of wood" (George Carlin)
Edited by user Friday, 27 August 2010 6:36:12 AM(UTC)  | Reason: Not specified
MatildaHQ Offline
#10 Posted : Wednesday, 8 September 2010 8:13:52 AM(UTC)
MatildaHQ
anyone have measurements for the length on stock standard hq springs? figured I'd ask here before puttin the old girl up on jacks to measure for myself
______________
Matilda the HQ
http://www.fastlane.com.au/forums/topic.asp?TOPIC_ID=25304
Big Al Offline
#11 Posted : Wednesday, 8 September 2010 7:15:29 PM(UTC)
Big Al
I can check tonight for you.
MatildaHQ Offline
#12 Posted : Friday, 10 September 2010 1:17:42 AM(UTC)
MatildaHQ
that'd be great, thanks
Steve
______________
Matilda the HQ
#13 Posted : Friday, 10 September 2010 3:17:55 AM(UTC)
Shocks can only control rebound and compression speed of the wheel. They are filled with oil which is forced through various sized holes which restricts the speed the shock shaft can travel at.
Gas filled ones create a more reliable dampening effect as the gas does not foam the oil up like air and hence the shocks will take longer to fade.
Adjustable shocks can have the dampening varied by adjusting the way the oil travels through the dampening holes/shims(depending on how high quality the shocks are).
The only way to stop bottoming out is to fit heavier rate springs. If the springs have been cut to go lower then expect bottoming as the spring rate will too light for the reduced wheel travel.
Big Al Offline
#14 Posted : Friday, 10 September 2010 4:28:15 AM(UTC)
Big Al
Steve, I just measured my front springs, out of a 6 cyl HQ sedan. In the longest part of the spring, so start to finish of the coil as such, I got 380mm and 384mm. Didn't think there'd be a discrepancy like that, but I suppose they are ~36 years old...
MatildaHQ Offline
#15 Posted : Friday, 10 September 2010 5:39:05 AM(UTC)
MatildaHQ
thanks heaps, appreciate the effort : )
Edit* When HQ's are lowered is it 2 inches off the compressed spring (ie. in the car bearing the weight) or 2 inches off the extended spring (out of the car) Also I assume the front and rear are the same length?
Steve
Edited by user Friday, 10 September 2010 6:10:59 AM(UTC)  | Reason: Not specified
______________
Matilda the HQ
Big Al Offline
#16 Posted : Friday, 10 September 2010 6:57:29 AM(UTC)
Big Al
I would imagine the spring is literally 2 inches shorter. Can check for you next week, getting a set of Lovells 2" lowered V8 springs delivered. pew pew!
#17 Posted : Friday, 10 September 2010 7:52:54 AM(UTC)
it is 2 inches out of the ride height. the spring length vary depending on the weight of the wire it is coiled out of. thats why after market springs are easier to fit than the standard springs. the aftermarket ones are made out of better steel and therefore dont sag as much under the weight of the car so therefore they can be made shorter but still have a standard ride height.
Edited by user Friday, 10 September 2010 7:55:01 AM(UTC)  | Reason: Not specified
blameyone Offline
#18 Posted : Tuesday, 14 September 2010 10:15:07 PM(UTC)
blameyone
Ring around a few suspension places ie Pedders and get their ideas on the way to go....Jack
blameyone Offline
#19 Posted : Tuesday, 14 September 2010 10:19:28 PM(UTC)
blameyone
Naturally the weight of the vehicle..motors etc can change the suspension quite considerably...Jack
adam PERTH Offline
#20 Posted : Wednesday, 15 September 2010 7:34:55 AM(UTC)
adam PERTH
go HQ racer spec??
Tuning for Holley carbs in Perth? PM me.
