#1 Posted : Wednesday, 20 October 2010 2:58:00 AM(UTC)
Hi All,is there an easy way to remove the window wiper "mechanize" on the drivers side of a HQ J X Z..........?OR is it strip everything off?
any help as my hx one has snapped and I only got one wiper working.pissin me off!
classic oz wreck Offline
#2 Posted : Wednesday, 20 October 2010 4:45:43 AM(UTC)
classic oz wreck
get your head under the dash and look up thru the air vent in the open position..you will need a long..really long extension bar...if its an a/c car remove the plate..
www.classicozwreck.com.au
#3 Posted : Wednesday, 20 October 2010 6:10:59 AM(UTC)
it's a right bugger of a job!
as greg said, the only way is up through the vent on the inside of the car
#4 Posted : Wednesday, 20 October 2010 6:18:27 AM(UTC)
Thanxz guys,Damn ..!
KeithA Offline
#5 Posted : Wednesday, 20 October 2010 7:38:21 AM(UTC)
KeithA
Know how you feel Jim, I've been looking at replacing the same part on my HQ. If you find an easier way, be sure to share it.
Keith
#6 Posted : Wednesday, 20 October 2010 4:05:56 PM(UTC)
Keith,If Greg,Dave and I dont know an easier way ,its not looking too good!!lol
gtrpu Offline
#7 Posted : Wednesday, 20 October 2010 5:58:23 PM(UTC)
gtrpu
There are 3 x bolts that hold it on and you need a 5/16 socket to get them. Two are easy to see but the third on is toward the front of the car and a bit harder to get to. I was lucky in that I removed mine with the dash out and no vents etc....but it was still a bugger of a job.
#8 Posted : Wednesday, 20 October 2010 7:23:44 PM(UTC)
classic oz wreck
geez guys its not that hard..remove right wiper arm,remove cowl vent,unclip right wiper arm link from wiper motor.remove lower dash panel...get fat arse under the dash with a long extension bar and go up thru the vent tube hole and undo..to install is a reverse of what i have noted plus a 6 pack of whatever grog may please you...
#9 Posted : Thursday, 21 October 2010 3:56:55 AM(UTC)
cut the cowl panel off replace and weld back on~ only joking but not a bad idea if its rusty !
#10 Posted : Thursday, 21 October 2010 5:42:41 AM(UTC)
cloudy,I'll practice on yours...now where is that 12" grinder...lol
adam PERTH Offline
#11 Posted : Thursday, 21 October 2010 10:08:46 AM(UTC)
adam PERTH
1/4 inch drive socket set with knuckle and small extension on the 5/16 helps a fair bit....
Tuning for Holley carbs in Perth? PM me.
#12 Posted : Friday, 22 October 2010 2:34:11 AM(UTC)
be nice jim I have a replacement for you with pin ,lol
#13 Posted : Friday, 22 October 2010 3:27:07 AM(UTC)
ok!!,that bribe worked....lol
KeithA Offline
#14 Posted : Monday, 25 October 2010 5:43:38 AM(UTC)
KeithA
Jim
Been waiting for you to find an easier way but you didn't come through. Replaced mine today. What a p***k of a job trying to do it through the vent. Eventually took the vent off and it was straight forward.
Keith
#15 Posted : Tuesday, 26 October 2010 1:29:58 AM(UTC)
Thanxz ,but I'll have to do mine later.
This page was generated in 0.129 seconds.
