#1 Posted : Monday, 8 November 2010 5:00:01 AM(UTC)
Why is the spark jumping from the plug cap to the coil on a V6? It still arks across the coil to where the lead plugs on even when the lead is pulled off. Its our excellent circle work car and is rubbish when it is only running on 5.
#2 Posted : Monday, 8 November 2010 7:38:53 AM(UTC)
Electricity finds the easiest ,shortest path.(something is cracked letting the spark escape)
#3 Posted : Monday, 8 November 2010 4:37:46 PM(UTC)
Measure the HT leads with a multimeter. My bet is that the no. 5 lead is open circuit.
Dr Terry.
#4 Posted : Monday, 8 November 2010 5:41:49 PM(UTC)
Thanks for the replies. Will have a go at testing the leads when I get a chance.
