Mick G Offline
#1 Posted : Sunday, 14 November 2010 6:24:26 PM(UTC)
Mick G
Hello,my Aussie 307 heads have a part no 3917290,and a single hump cast in to the front.What are they?Are they the orig's?Cheers,Mick
Water makes it's own sauce
#2 Posted : Sunday, 14 November 2010 8:37:58 PM(UTC)
327
68-70
1.72/1.50
Mick G Offline
#3 Posted : Sunday, 14 November 2010 9:42:20 PM(UTC)
Mick G
Would these heads be orig,as the old girl seems to have the matching 4 barrel manifold?Cheers,Mick
#4 Posted : Monday, 15 November 2010 3:49:25 AM(UTC)
These are 327 heads ,not original,yours should be...3795896...3911032.etc (about five different types).probably the 3911032"s...what number is the manifold?Its hard to fit a manifold that doesn't match so to speak.I have an 327 engine that your heads fit.
#5 Posted : Monday, 15 November 2010 4:14:31 AM(UTC)
Those heads are standard truck type small valve 1968-70 327 heads. These were also fitted to 327's as fitted to early HK GTS327 and all Aussie assembled 1968 Impala, Parisienne etc with 327ci SBC. They are not really that much different to the original 307 heads from HK-HT with 307 (3911032 as Jim says).
Mick G Offline
#6 Posted : Monday, 15 November 2010 4:37:43 AM(UTC)
Mick G
Guys,the manifold no is 3927184.Thanks heaps
#7 Posted : Monday, 15 November 2010 5:16:56 AM(UTC)
manifold is from a 3927184
350...chev
1969...year
4-Brl...quad
so to summarizer...you have
a 307 with 327 heads and a 350 manifold..ok
