Dick Offline
#1 Posted : Monday, 6 December 2010 4:34:18 AM(UTC)
Dick
will a vp auto box bolt up to a 253 engine will i have to change the bell houseing and that
#2 Posted : Monday, 6 December 2010 5:15:24 AM(UTC)
wont fit on wrong pattern block and the bellhousing is incorporated in the complete
box casing ,so thats a big nope cant do it.(except crappy adapter plates tri to turbo)or block re-drill
Dick Offline
#3 Posted : Monday, 6 December 2010 5:38:00 AM(UTC)
Dick
dam thought it mighta work oh well just have to chase up auto bow 2 suit
#4 Posted : Monday, 6 December 2010 4:35:19 PM(UTC)
There are a few other ways to do it (has to be a V8 box though).
1. Find a Bedford 253 - these are TH pattern.
2. Get your 253 block redrilled to TH pattern (only mid-late 1974 onwards blocks).
3. Get the gearbox housing modified to suit trimatic pattern.
edelbrock1 Offline
#5 Posted : Monday, 6 December 2010 5:34:59 PM(UTC)
edelbrock1
How hard would it be to find one of these blocks?? Do you know how many were made??
I would have thought they would be rarer than a 186S air con head.
#6 Posted : Tuesday, 7 December 2010 1:22:38 AM(UTC)
I've never seen one in the flesh, but they were/are around. They are really nothing special, just an xS prefixed blue 4.2 (low comp), same thing as a WB series WS prefixed engine. Only major difference was the TH pattern drilling and they also ran a 2 barrel Rochester (like a HK-HT 307) with a governer. The real oddball is the BV prefixed engine, the only place a low compression 308/5.0L was used. Obviously V being the next available engine code after R,S,T,U eg HR, QS, 11WT, QU (never been sure why the L34 engine was HZ rather than HV or HY!). This one also had the 2 barrel, on both the BS and the BV engines a 4 barrel blue intake was used with a carby adapter which included the governer.
#7 Posted : Tuesday, 7 December 2010 1:34:27 AM(UTC)
Dick,just get a good trimatic,they are good enough to handle a 253.try get a 308 one they are slightly better.
Dick Offline
#8 Posted : Wednesday, 8 December 2010 2:19:40 AM(UTC)
Dick
yer i got 1 in my hz wagon so i might change the wagon box and throw the 4 speed in it and use the auto in the vp ute
