adam PERTH Offline
#1 Posted : Thursday, 23 December 2010 10:12:45 AM(UTC)
adam PERTH
Off to pick up 2 x 283's tommorrow.
ex 1960 belair and a 61 El camino.
as luck would have it, i have "lent" my chevy book out to someone and i need to know if these had the early engine mount bosses?
i think that the early mounts were from 1955-58???
the 61 camino motor comes with a 3 speed box attached. any ideas what this would be. synchro? or non synchro?
Tuning for Holley carbs in Perth? PM me.
#2 Posted : Thursday, 23 December 2010 5:28:55 PM(UTC)
They will be side mount engines. The 3spd might be a 3spd Saginaw or 3spd T10.
adam PERTH Offline
#3 Posted : Saturday, 25 December 2010 11:17:01 PM(UTC)
adam PERTH
cheers for that.
got them home and the 3 sp is a saginaw hanging off a 283 with powerpakies
this one them has a 4GC Rochester - anyone got an opinion on these?
the second motor has a 61-66 casting 283 block, with 60-67 casting heads that say 1.72 / 1.5 valves off the casting numbers website. this motor has the symbol at the the front just like a powerpak, except without the little triangle on top.(SO THESE JUST HAVE A LARGE RECTANGLE ONLY)
would these heads still be regarded as powerpak?
Edited by user Saturday, 25 December 2010 11:18:14 PM(UTC)  | Reason: Not specified
#4 Posted : Monday, 27 December 2010 10:11:01 PM(UTC)
A 61 Chevrolet 3-speed manual gearbox is a Saginaw with synchro on 2nd & 3rd only.
One point though. To my knowledge there where no El Caminos built in 1961, 62 or 63.
adam PERTH Offline
#5 Posted : Monday, 27 December 2010 11:15:41 PM(UTC)
adam PERTH
i didn't look at the tags on the el Camino, but the front end looked just like a 1960-61 Belair..
the motor out of it is a date coded 1960 or thereabouts.
blameyone Offline
#6 Posted : Monday, 27 December 2010 11:46:48 PM(UTC)
blameyone
adam , if you can give us some head and block cast # I can tell you what they came out !....Jack
blameyone Offline
#7 Posted : Tuesday, 28 December 2010 3:36:51 AM(UTC)
blameyone
Correct on that Dr Terry. No ElCaminos1961- 62 or 63.
This page was generated in 0.558 seconds.
