hkute68 Offline
#1 Posted : Sunday, 20 March 2011 4:13:21 AM(UTC)
hkute68
number gurus can you please decipher this red 6 head number
7420109 G134 8.
thank you.
#2 Posted : Sunday, 20 March 2011 6:54:06 AM(UTC)
JULY 13TH 1964 ...149 OR 161 HEAD I THINK.
hkute68 Offline
#3 Posted : Monday, 21 March 2011 10:36:56 PM(UTC)
hkute68
thanks jim, do you think it could be 179 also?
#4 Posted : Monday, 21 March 2011 10:53:57 PM(UTC)
To my knowledge this could only originally be from an EH or HD 149 hi-comp engine.
The 161 head had an extra water hole at the front face & uses a different casting number.
The EH/HD 179 (& also the rare 149 lo-comp) used a head with a larger combustion chamber & therefore a different casting number again.
#5 Posted : Monday, 21 March 2011 10:55:50 PM(UTC)
It will fit but be pretty high compression if it is a high comp 149 and 161 head.
hkute68 Offline
#6 Posted : Tuesday, 22 March 2011 7:38:20 AM(UTC)
hkute68
thanks for the info guys it was fitted to my 186 lc xu-1 when i bought it many years ago.was that a common thing back then?
#7 Posted : Tuesday, 22 March 2011 5:59:32 PM(UTC)
The XU-1 head is similar to the 149/161 head especially in the combustion chamber area. If the engine suffered a cracked head in the past, a 149 head would have been a good substitute, given some valve & port work.
