number gurus can you please decipher this red 6 head number 7420109 G134 8. thank you.
JULY 13TH 1964 ...149 OR 161 HEAD I THINK. |
Jim in Adelaide.. |
thanks jim, do you think it could be 179 also?
Thanks: 1 times Was thanked: 243 time(s) in 217 post(s)
To my knowledge this could only originally be from an EH or HD 149 hi-comp engine.
The 161 head had an extra water hole at the front face & uses a different casting number.
The EH/HD 179 (& also the rare 149 lo-comp) used a head with a larger combustion chamber & therefore a different casting number again.
Dr Terry |
Thanks: 1 times Was thanked: 606 time(s) in 573 post(s)
It will fit but be pretty high compression if it is a high comp 149 and 161 head. |
thanks for the info guys it was fitted to my 186 lc xu-1 when i bought it many years ago.was that a common thing back then?
The XU-1 head is similar to the 149/161 head especially in the combustion chamber area. If the engine suffered a cracked head in the past, a 149 head would have been a good substitute, given some valve & port work.
Dr Terry |
