domc Offline
#1 Posted : Wednesday, 6 April 2011 9:40:18 PM(UTC)
domc
Hi I'm trying to find out weather the door protector strips on my HQ are original or aftermarket. My car was resprayed many years ago and they look different to some NOS ones I have seen. Can you get good repro ones for starters or are there some generic type ones out there? Does anyone have a photo of original ones on their car they can send me please? Were these the same from HQ to HZ? Cheers
#2 Posted : Wednesday, 6 April 2011 11:37:51 PM(UTC)
The aftermarket ones were generally stick on type, I have seen a couple of different type of clip on ones my hx prem has ones about 2cm wide alloy/stainless with smooth black centre strip , my hj stato has a slightly narrower type but the black centre strip has a grain type pattern in it which could be luxury car type ? but both are clip on.
#3 Posted : Thursday, 7 April 2011 3:51:04 AM(UTC)
Cloudy is spot on. However I don't think HQ had side strips standard, not even sure if they were optional. HJ and HX Kingswood and Premier certainly had them (same except HJ textured and HX smooth) but I don't recall ever seeing a HQ Premier with factory strips. Dr Terry would know for sure.
#4 Posted : Thursday, 7 April 2011 4:06:35 AM(UTC)
I Agree with Byron,I don't ever recall a protector type strips,only chrome I know of is the one by the bottom of the window on prems,but thats not a protector strip.
justgm Offline
#5 Posted : Thursday, 7 April 2011 5:02:46 AM(UTC)
justgm
Hi All , NASCO , Holden HQ body side moulding packages , 2823151, 2823152, 2823153. 2823154, 2823155, AN2066 , 27/1/72 . Quote " to ensure a continuous moulding line and moulding clearance through door swing , it is essential that front and rear doors line up with front fender and rear quarter panels respectively ." This is from a NOS set for an HQ S/W I have . Mark.
#6 Posted : Thursday, 7 April 2011 6:19:56 AM(UTC)
The HQ accessory brochure shows side strips as an option.
domc Offline
#7 Posted : Thursday, 7 April 2011 10:52:14 AM(UTC)
domc
yeah they are listed in my HQ parts catalogue
#8 Posted : Thursday, 7 April 2011 3:46:28 PM(UTC)
It'll make them harder to find being an accessory only. Hopefully someone has put HJ or HX ones on your car! Have a look at HJ and HX parts catalogues and see if either are the same part number as HQ accessory strips too.
justgm Offline
#9 Posted : Friday, 8 April 2011 3:07:31 AM(UTC)
justgm
HQ moulds were held on with clips , not stick on . and are HQ only . Mark.
Rhys Offline
#10 Posted : Friday, 8 April 2011 8:56:11 PM(UTC)
Rhys
Hi Mark,
How were these HQ clips attached to the doors, rivets?
#11 Posted : Friday, 8 April 2011 9:38:19 PM(UTC)
They were a bit agricultural actually. They came as an accessory kit thru spare parts & you just drilled holes in the door skins as required. There was no attempt at waterproofing. The clips were just a generic spring wire type.
The factory HJ/X/HZ type were mounted on plastic clips which clipped over welded studs, as commonly seen since the HK series. This type is far superior.
domc Offline
#12 Posted : Saturday, 9 April 2011 5:31:14 AM(UTC)
domc
So they would not have been fitted at the factory then??
#13 Posted : Saturday, 9 April 2011 6:06:12 AM(UTC)
dont think so.
justgm Offline
#14 Posted : Tuesday, 12 April 2011 5:49:12 AM(UTC)
justgm
Do not know if the moulds were factory fitted ? but the clips are plastic 2822317 ,2822275,2822276 , screw sp-2248, sealer 7417028 " to effect a water tight seal " , an internal cap was fitted to the boot part of the screws 7448475 , Terry is correct in saying these moulds were nomally poorly fitted , and rusted around the screw holes . Mark.
#15 Posted : Tuesday, 12 April 2011 7:27:22 PM(UTC)
Yes, AFAIK there were no factory-fitted side mouldings on HQs.
classic oz wreck Offline
#16 Posted : Tuesday, 19 April 2011 3:36:08 AM(UTC)
classic oz wreck
i have wrecked a hell of a lot of hq with the so called non factory fitted side moulds and have a lot of second hand and also nos strips..i even have a pair of quarter panel strips for an hq coupe..the export chev hq i wrecked also had these strips..clips were large plastic and were held on by screws which you had to drill the hole first.
www.classicozwreck.com.au
#17 Posted : Tuesday, 19 April 2011 3:59:58 AM(UTC)
Yeah Greg,I've see bucket loads of these,but was sure they were "aftermarket" and all the "rage" back then...could be wrong.
#18 Posted : Tuesday, 19 April 2011 8:51:13 PM(UTC)
classic oz wreck
jim,i am pretty sure that they are nasco accessories so they must have been dealer fitted..the nos ones i have here are all wrapped in plastic with handwritten gm numbers on white tags..
domc Offline
#19 Posted : Wednesday, 20 April 2011 8:20:12 AM(UTC)
domc
adam PERTH Offline
#20 Posted : Wednesday, 20 April 2011 9:03:58 AM(UTC)
adam PERTH
i am with greg. see/ wreck too many not to be standard. I will have to find some solid evidence the next time whenn i am tripping over HQ stuff.
