4 Pages<1234>
#21 Posted : Thursday, 9 June 2011 7:29:57 AM(UTC)
Not quite right. VIN number is on the skinny tag. In that example the PSN is H512345 which is the last part of the VIN.
The firewall stamp is the chassis number.
The body number is on the BODY plate. This body number varies between plants, only some plants had a #1 for each model in a series. Others it was an accumulative number for all models in that series.
rallystripes Offline
#22 Posted : Thursday, 9 June 2011 7:53:01 AM(UTC)
rallystripes
Ok,so we all can concur that without his tags,going off the firewall number and that alone,dosent tell us it was an GTS 327 or 307 or whatever.
I remember a HT Bathurst like this for sale and turned away coz it had no tags.
I know there are other things unique to Bathurst cars to tell them apart but i guess he really does need those tags.
Thats why i went on about the firewall number because if it is unique,the record can say "yes,firewall number 12345 was one of our 327 specials" at least he could have that as proof that his car is genuine.
#23 Posted : Thursday, 9 June 2011 4:37:15 PM(UTC)
Plant Sequence number is contained within the VIN. The VIN number and VIN system is well documented.
Chassis number is on ADR plate for HT-HG post 1/1/70. Prior to that it is a standalone number.
#24 Posted : Thursday, 9 June 2011 6:03:33 PM(UTC)
Originally posted by HGGTS
I consider the small skinny tag to be the manufacturers serial number (call it vin if you must).
But the vehicles chassis number for id/rego purposes is definitely the number stamped on the firewall. I believe this chassis number was also on the compliance tag for HT/HG models.
This confusion exists because the various state rego authorities (RTA etc.) now use the term VIN to describe what the rest of the world knows as the chassis number, yet the long skinny tag has the number that we know as the Holden VIN for the older cars.
As Warren has said the GM-H VIN system is well documented & has been around since the 60s.
I use the term VIN for the Holden VIN for these cars & the term chassis number for the firewall (or chassis on HQ-WB) stamping. The chassis number is also repeated on the ADR compliance plate for cars 1/1/70 onwards.
This confusion does not exist for Holdens VN onwards. The Holden VIN & chassis number are the same as part of the ISO-VIN system.
For HK etc. the body number is a separate number again & is only stamped on the body plate.
Dr Terry.
#25 Posted : Thursday, 9 June 2011 7:03:55 PM(UTC)
considering 80737 tags would also be something to sell or use why wouldnt they take them as well? sounds a bit sus.
80569K Offline
#26 Posted : Thursday, 9 June 2011 8:06:32 PM(UTC)
80569K
Not trying to muddy the waters but...
Very confusing as far as HK's go, I'm just a dumb old pensioner so please bear with me, lol.
I will use the numbers off my car as an example.
The firewall stamp is on the body but it is actually the chassis number and it is applied at the factory which made that body. eg, HK0471#B (no second B) which means that it is the 471#th HK body MADE at Brisbane. Nothing to say that it could not have ended up on a Perth car for example.
When it went down the production line at Brisbane the body (big) tag was fitted and the plant sequence number eg, HK569A-0359#B becomes the body number. Which makes it the 359#th HK ASSEMBLED at Brisbane. Confused yet? Hang on that's 1114 numbers different? Don't reckon they'd want to store a thousand bodies out in the backyard.
The skinny tag is installed at the same time as the big tag and it is 80569KH10504#. Which makes it the 504#st GMH vehicle of all types built at Brisbane since 1/1/1968.
You want more confusion? I have had the area around my firewall stamp back to bare metal and the second B was never stamped on it, so it must have missed the train and ended up on a Brisbane car.
So now we have 3 different numbers to identify that vehicle, no wonder I'm confused and now you want to call one of those numbers a VIN number, I thought that the term "VIN number" did not exist before 1/1/1970.
To top it all off the tags were stamped differently from one factory to another, so I can readily see why for HK's the firewall stamp is the only true identifier.
Edited by user Thursday, 9 June 2011 8:35:24 PM(UTC)  | Reason: Not specified
#27 Posted : Thursday, 9 June 2011 8:11:05 PM(UTC)
OK, I may be wrong here but........ with the number stamped on the firewall that should mean that if anyone tries to use the tags on another car they should come up as stolen anyway? So if the tags have been reported to the police they should show up on revs as "currently under police investigation" and imposible to use anyway? The tags should now be of no value whatsoever? Dont they compare the firewall stamped number with the tag number when a blue slip is issued?
As far as I can see, if the tags are reported stolen and not recovered that Monaro now has to cease to exist, making reprinted plates impossible anyway.
80569K Offline
#28 Posted : Thursday, 9 June 2011 8:33:35 PM(UTC)
80569K
Would that not rely upon the production records still being available.
To use my car again, I live in NSW but I wanted to find out it's original QLD number plate. QLD DOT records only go back so far, in this case 1992 was as far as they could look back.
Luckily for me the clerk who did the plate change in 1992 recorded the old plate details and luckily again the data operator who transferred the info from handwritten files to computer recorded the number also.
Edited by user Thursday, 9 June 2011 8:41:34 PM(UTC)  | Reason: Not specified
#29 Posted : Thursday, 9 June 2011 8:43:49 PM(UTC)
The way it was explained to me years ago by a long serving GMH spare parts guy, was...
1. the body plate. is for spare parts, eg correct colour seat belt, paint trim ect, (also cross referenced against the build date on later cars ADR plate)...
2. the Production Sequence Number (not a VIN, a vin has 17 digits/letters) is for warranty, recall & quality control..
3. the Chassis No (later includes the ADR plate) is for the government..
The first two are not needed for Registration, but the third is..
80569K Offline
#30 Posted : Thursday, 9 June 2011 9:06:58 PM(UTC)
80569K
That explanation sounds good to me.
#31 Posted : Thursday, 9 June 2011 10:26:42 PM(UTC)
Just to clarify a few things.
80569K said "I thought that the term "VIN number" did not exist before 1/1/1970."
You are confusing VIN with ADR. The term ADR wasn't used before 1/1/70 as this was the date of the ADRs & associated compliance plate introduction. ADR = Australian Design Rule.
VIN simply means Vehicle Identification Number. Have a look at an HK workshop or parts manual, a VIN plate numbering breakdown is listed quite clearly.
Monaro202 said "2. the Production Sequence Number (not a VIN, a vin has 17 digits/letters)"
The Holden VIN includes the PSN (Production Sequence Number) & it IS their VIN. The RTA began calling the chassis number their VIN around the mid 80s.
Also the RTA VIN doesn't necessarily have 17 digits, this was only for the so-called ISO-VIN which commenced around 1990.
80569K said "To top it all off the tags were stamped differently from one factory to another, so I can readily see why for HK's the firewall stamp is the only true identifier."
Spot on, the only true identifier of any car is the chassis number. As far as the RTA are concerned, the body & VIN tags are irrelevant. Also the reason the plates are stamped differently is because they a stamped at different places at different times. The body plate is stamped & fitted as the body is built often before painting. The VIN & ADR plates are fitted post assembly & AFAIK the ADR plates are all stamped at one location (presumedly Melbourne) because of the associated legalities.
playwme Offline
#32 Posted : Thursday, 9 June 2011 11:52:21 PM(UTC)
playwme
From what I gather so far this isn't the case. There isn't a single number on any of the plates that the RTA really give a crap about (apart from the build date). Therefore, reporting them stolen wont show anything on a REVS check as none of those numbers need to be punched in.
playwme Offline
#33 Posted : Thursday, 9 June 2011 11:54:49 PM(UTC)
playwme
Which record? The RTA don't have these and Holden if they did have them couldn't be arsed manually searching through them to clarify something that's not making them any money.
#34 Posted : Friday, 10 June 2011 1:00:13 AM(UTC)
Dr Terry is spot on. BODY tags belong to the Body Assembly Plant. VIN tags were outsourced with the PSN already stamped. The Vehicle Assembly Plant added the first bit onto the VIN tag before the PSN (and on later VIN plates the last digit signifying the series), this is why the first and last bits are always misaligned. The ADR plates were stamped under the control of some government dept in Victoria and sent to the assembly plants.
#35 Posted : Friday, 10 June 2011 1:12:07 AM(UTC)
Oh, well if there is no vin or unique serial number on any of the tags then I dont suppose they would show up as stolen. If thats the case it must be impossible to prove any of the tags belong to any hk?
#36 Posted : Friday, 10 June 2011 1:47:06 AM(UTC)
Basically true. You can tell if they are NOT from the shell (that is where the Holden Monaro Register comes in handy), but it is hard to tell for certain that they do unless you have original books. Even those have been faked as evidenced in recent times.
#37 Posted : Friday, 10 June 2011 3:23:32 AM(UTC)
rallystripes
Well it looks like all you have is the chassis number left on you car and from what has been discussed on here,it dosent tell us your car is a 327 GTS from factory.
You would however have other unique features to your car that would set it apart but im sure you could option up a 307 with the same features.
If you dont have the log books maybey you still have the old rego papers with all the numbers on it which could show all the numbers together.
Other than that,you know what it is and enjoy it for what it is.
tbm Offline
#38 Posted : Friday, 10 June 2011 4:00:36 AM(UTC)
tbm
Quite a few people are missing the point. These tags are what identifies a monaro body shell as being more or less valuable than another. eg a 327 gts is worth more than a base model 161. The way to truly identify one along with having all its required parts in place, is these tags. The people that know theses cars can usually tell if the tags have been removed or not and the fact that mine had not been made it rare in itself. I purchased my monaros all back in the mid to late 90's when they were not very popular or valuable. i never considered them to be something that i would ever make money out of and considering i never sold any of them when the ridiculous prices were around even tempting as it was, proves that they were more important to me than the money. In saying that i could never say never and if circumstances required then who knows. What has really hurt me the most is the fact that the person/s who did this to me are more than likely someone i know. For them to go to the trouble that they have and to try and decieve me and hide what they have done upsets me greatly. I would be having a whole lot less trouble accepting this had happened if the plates were gone and that was that. then i could believe that it could have been an opportunistic crime committed by just about anyone. But for the plates to have been taken and changed there are reasons that show it is entirely an inside job and involves people i once considered friends. I dont believe i will ever see my plates again i am more about finding someone to be accountable for their actions in one way or another.
tbm Offline
#39 Posted : Friday, 10 June 2011 4:04:49 AM(UTC)
tbm
Oh and by the way the young twenty something year old copper just really didnt get it at all. It was almost like whats a monaro and what are id tags. Really didnt fill me with much reason to think that their investigation would last very long at all.
blameyone Offline
#40 Posted : Friday, 10 June 2011 5:43:19 AM(UTC)
blameyone
Like rallystripes says, you know what the car is and unless you want to sell the car it's not going to be an issue. You have'nt lost the car and you never know your freinds may come clean with the tags happy that they got a stir out of you. Apart from all that if those tag numbers turn up on another car then you may have an issue...in the mean time let every one know those tag numbers so they will be easily recognised....all the best one way or another.
Guest (11)
4 Pages<1234>
This page was generated in 0.189 seconds.
