4 Pages<1234>
D. A. Barnes Offline
#21 Posted : Saturday, 3 September 2011 3:16:45 AM(UTC)
D. A. Barnes
Originally posted by Mr Bob Dobalina
Originally posted by D. A. Barnes
the only answer is that the numbers were done after painting as if they were painted over as suggested then they should not have rusted like they do.
This is not conclusive proof, corrosion occurs where stress and energy levels are highest, ie around deformations such as stamping, regardless of which stage it was painted.
Very interesting point. But it is amazing how only where the letters have broken the paint rusts. I only wish I had photos to back up what I have seen in this regard. So can you explain why the deformation in the metal around the heater core housing in a HQ firewall does not rust like the letters in the firewall number? I don't doubt what you have said but there is a real world difference between reality and theory.
Mr Bob Dobalina Offline
#22 Posted : Saturday, 3 September 2011 3:23:01 AM(UTC)
Mr Bob Dobalina
Well it's not a theory, it's a conclusion based on observation and experimentation over a couple of thousand years (ie since approximately the beginning of the Iron Age around 1200BC). I was just stating that it's not conclusive proof, the fact that it is stamped afterwards would also lessen the bond between paint and substrate, adding to the likelihood of corrosion.
#23 Posted : Saturday, 3 September 2011 3:32:32 AM(UTC)
D. A. Barnes
Hi Bob, Thank you for this. I wasn't sure if you were taking the mickey out of me. You sound like an extremely intelligent person who knows a great deal about metals and your contributions here are highly valued.
#24 Posted : Saturday, 3 September 2011 3:44:11 AM(UTC)
i'm starting to like bob, he has added a new "dynamic" to this now lame, and fast diminishing series of contributions on virtual land
well done bob
#25 Posted : Saturday, 3 September 2011 8:12:33 AM(UTC)
I am assured that a read of the HK Engineering manual will show how and when and where chassis numbers and VAP stamp are stamped. A close look at post HQ release HG and LC chassis numbers should also demonstrate that the chassis number on these was stamped by a device capable of carrying and stamping 8 digits. The A suffix on those cars does not align with the rest of the number in most cases. As DA says HQ-HZ Pagewood firewall numbers and also Elizabeth HQ cowl numbers are the same machine stamp.
The HKTG Garage Offline
#26 Posted : Saturday, 3 September 2011 9:19:43 AM(UTC)
The HKTG Garage
Common sense on this one. If anyone has or had worked at a Holdens, they would remember the processes involved. I am 99.9% sure that HK HT HG firewall numbers were stamped into the firewall panel in the press shop when the panel was pressed out. Being sequential numbers allowing the operater to change the digits as the number got bigger. The paint wasnt as thick in those days. They didnt use high fill two pack primer as most tend to now which fills the indentation of letters/numbers. Think about it. If the number wasnt stamped into the firewall in the press shop when the panel was pressed out in a horizontal position, when was it done? If not done in the body or paint shop do some honestly think a trim shop process worker hopped inside the engine bay while the body was moving down the line, and stamped a number in each car on a vertical panel? I dont think so.
#27 Posted : Saturday, 3 September 2011 6:28:07 PM(UTC)
Read my post directly above. I had the same common sense vision you did, but apparantly it was done once the shell was completed in the BAP. Remember the car as it left the BAP was firewall back only ie body assembled, painted and hard trimmed. The HK Engineering manual details all this. The front was put on in the VAP which is a separate plant. The tool that stamped the numbers was a compressed air operated device.
#28 Posted : Saturday, 3 September 2011 11:14:37 PM(UTC)
The HK engineering report states the following:
Vehicle serial number at each body assembly plant starts at 00001 and is prefixed by model series and suffixed firstly by a body plant letter where the body is built and a second by V.A.P. letter where the vehicle is ultimately built.
It does not state when or where the stamping is done, unless I am reading this wrong. The confusion here might be the "by V.A.P. letter" being read as "by V.A.P."
Warren
#29 Posted : Monday, 5 September 2011 1:41:02 AM(UTC)
D. A. Barnes
Originally posted by Warren Turnbull
The chassis number stamping, according to Ben, is always stamped after painting. So the inner guards of FE to EH, chassis on HQ to WB, front member of Commodore and Gemini etc would all be the same. Stamped after final painting.
The reason being is a chassis/identification number is not allowed to be painted over.
So any Holden with a stamped chassis number can be checked to see if stamped before or after painting, not just HD to HG and LC and LJ Torana.
I shall still stand behind the second S on my car being stamped before painting, but this might not be relevent to the full chassis number. Even though GMH include it in the number according to their literature.
Warren
Hi Warren, Adding fuel to the fire I have just been to the Father's Day Australian car event at Lakeside where there were many old Holdens and Falcons. You were spot on about the EJ and EH Holdens inner guards in that the numbers were stamped after they were painted as you could see the effect inside the individual letters. They were quite deep stamps as well and the Brisbane cars were very rough compared to Sydney. Some nice original HK monaros also had the proof that numbers stamped after paint as well as LJ Toranas.
#30 Posted : Monday, 5 September 2011 4:13:26 AM(UTC)
The HKTG Garage
Barnes, there aint no proof that HK HT HG were stamped on the firewall after being painted. You certainly can not lean into an engine bay at a car show and tell. I still dispute it and am currently studying firewall cuts and have people who still work at the Elizabeth Plant on the job to back me. Watch this space.
#31 Posted : Monday, 5 September 2011 11:39:47 PM(UTC)
After looking at this and talking to Ben, possibly Elizabeth was done differently to Pagewood and Acacia Ridge. This may explain why we are all seeing different things:
http://www.ebay.com.au/i...Cars&hash=item415ceb8f7b
From the original, unpainted cars I have (Acacia and Pagewood) i'm certain they are stamped after painting. I don't have an Elizabeth or Dandenong in original paint to look at.
petaus Offline
#32 Posted : Monday, 5 September 2011 11:58:52 PM(UTC)
petaus
that fire wall is a thick piece of steel from memory not just like a guard, maybe the paint near really got in there because its pretty fine stamping???
anyway i reckon it would of taken some force to stamp that would need some form of backing from behind, not possible once fitted to the car and if it was stamped after paint why??? not long after the vin tag would of been fitted, bap plant has one form of serial number the vap another???
if it was stamped at the vap they could of easy used the vin tag number by that stag it would of been on the build sheet by then?
#33 Posted : Tuesday, 6 September 2011 2:48:05 AM(UTC)
The device that stamped them was compressed air operated.
VIN tag may not have been fitted for a fair while, depending upon what State the VAP was located in.
#34 Posted : Tuesday, 6 September 2011 4:19:40 AM(UTC)
The HKTG Garage
So, as to avoid any confusion, when at the Elizabeth Plant the shops in order were:
Press Shop
Body Shop
Paint Shop
Trim Shop (The largest. This line was a continuation of the paint shop line.)
VAP (Vehicle Assembly Plant)
Press Shop, Trim Fabrication (Interior)and Plastics were all seperate factories. The production line started in the Body Shop and ended in the VAP where the vehicle was driven off.
Possibly called by different names at other Plants?
#35 Posted : Tuesday, 6 September 2011 4:24:09 AM(UTC)
The HKTG Garage
I'm think 100% accuracy required here, especially if you believe the vehicle was painted and half assembled when stamping it. There would of been no room for error.
Yet if it was stamped into the firewall panel in the Press or Body Shop (with some force mind you and would of had to have had something behind it) and a mistake was made, a lot easier to discard the panel and replace before the car is even partially assembled.
#36 Posted : Tuesday, 6 September 2011 5:37:54 AM(UTC)
I agree, I raised this the other day discussing it, what happened if there was a stuff up? We know what happened with HQ-WB rails if a number was repeated, but HK-HG?
#37 Posted : Sunday, 25 September 2011 8:03:26 PM(UTC)
I have been trying to find some conclusive evidence on this.
I have looked at a couple of HB Toranas and they are definitely stamped afterwards. My reasoning is as follows. The numbers are rusted and the paint is flaking away around the number, this is on cars that have not been left out in the rain and still have their bonnets on. No other rust is in the engine bay, except where paint has been scratched off.
I have never seen the same thing on an HK to HG, or LC/LJ. But have on three HBs, one Brisbane/Brisbane, one Brisbane/Sydney and one Adelaide/Melbourne.
As I have already stated the second S on Sydney caars is stamped before painting, as they are often illegible due to paint covering it.
The rest of the number is the question mark. As Ben has said, not allowed to painted over, but difficult to stamp into firewall after assembly.
To solve the riddle I have been looking for a magazine that came out many years ago and it had a photo of an HK entering the paint shop, with writting all over the firewall. I have asked a few people to look for it.
The good news is I found it today.
It was a Street Machine "Hot Holdens" mag from around 1988. (Yellow HK on cover with, bonnet only with carbies through bonnet with polished allow catcher on top) It has the A9X Vs HT 350 test, and 20 years of Monaro special. On Page 16 you will find the photo.
I can tell you that the Monaro is an HK from Melbourne, as you can see and read the chassis number stamped into the firewall. There is NO paint on the firewall.
So the answer is HKs were stamped BEFORE painting.
Warren
#38 Posted : Sunday, 25 September 2011 10:23:55 PM(UTC)
The HKTG Garage
I knew it!
Well done Warren. Can you scan and email the pic to me please?
#39 Posted : Sunday, 25 September 2011 11:12:31 PM(UTC)
What happened with HQ-WB rails Byron?
#40 Posted : Monday, 26 September 2011 1:37:39 AM(UTC)
I'm not sold on firewalls being stamped prior to painting. Possibly Dandenong only by Warren's research? By the vehicles i've seen Pagewood, Acacia Ridge and Elizabeth appear to be stamped post paint. HQ-WB rails would have been stamped after paint.
Guest (12)
4 Pages<1234>
This page was generated in 0.088 seconds.
