4 Pages<1234>
#41 Posted : Monday, 26 September 2011 1:58:55 AM(UTC)
I was wondering about when they were repeated Byron?
#42 Posted : Monday, 26 September 2011 2:29:10 AM(UTC)
I have sent the photo Simon.
It also proved a point to myself that the front end was on the car when it was painted, this may have only been for BAP and VAP the same. But I remember no paint between the front end and the body when I pulled it apart.
As I was going off memory I did not say anything before, until I had proof.
Byron, there would be no reason for a different process at each plant. Ben's theory that a chassis nummber cannot be painted over is not correct, as if this was the case ALL plants would have to be the same.
The car in question here has a build sheet attached to it, so was probably a 1969 vehicle.
When you see an HB Torana chassis number you will see what happens when you stamp a number into a painted surface, and I am afraid they are nothing like an HK to HG or even a Sydney HQ.
If Simon knows how, I do not, maybe he can post up the pic.
Warren
#43 Posted : Monday, 26 September 2011 4:29:59 AM(UTC)
Ok here is the picture being spoken about.
this is the same picture but less cropped
Which I assume is showing the car being sandblasted.
Cheers Paul.
Edited by user Monday, 26 September 2011 4:30:55 AM(UTC)  | Reason: Not specified
#44 Posted : Monday, 26 September 2011 4:33:46 AM(UTC)
Now on the firewall stamping side of things I think this one shows that at least with HR's from Perth
that the P was stamped later.
it is also interesting to see on this more weathered car that the other letters are rusting but not as much as the P.
Edited by user Monday, 26 September 2011 4:34:24 AM(UTC)  | Reason: Not specified
#45 Posted : Monday, 26 September 2011 4:38:25 AM(UTC)
Now on the HQ Adelaide firewall number if this was done with some sort of number jig it must have had bad days.
Another picture I always found interesting was this one
it shows why the upper sections of HQs were so prone to rust.
I would assume also that previous models would have been dipped to about the same level.
Cheers Paul.
#46 Posted : Monday, 26 September 2011 4:48:38 AM(UTC)
while on the painting side of things this shows a car that must be being completed at this plant and what it had on it at paint time.
where as this I assume shows cars that were to be completed elsewhere
So painted without front chassis attached. (at least on the HK's not the torries)
Cheers Paul.
Edited by user Monday, 26 September 2011 4:49:39 AM(UTC)  | Reason: Not specified
The HKTG Garage Offline
#47 Posted : Monday, 26 September 2011 5:03:21 AM(UTC)
The HKTG Garage
This is all interesting stuff. Thanks for the email Warren. I'm still going with the fact that the subframe was painted seperate from the body. The firewall is clearly a different colour and they wouldnt of masked them up to purposely paint them the two different shades. I believe the body came through the paint shop without the subframe. It was masked up and painted along with the boot compartment after the final colour was applied in what was called "Third Colour" when I was at Elizabeth. The photos of the HK's being painted with subframe on must of been export vehicles as they had body colour engine bays and boot compartments. I can definitely prove there is paint on the firewall where the subframe mates up. I may have to take some photos and email them to someone who knows how to upload them on here.
Blocker Offline
#48 Posted : Monday, 26 September 2011 5:18:27 AM(UTC)
Blocker
Thanks for sharing these great pics hqss.
I thought I would share this scan relevant to your 'dipping' photo.
#49 Posted : Monday, 26 September 2011 5:57:43 AM(UTC)
If anyone else has photos they want to add here feel free to email them to me at hqss@oldholdencom (just add the dot before com)and I will post them for you.
Thanks heaps Blocker that is the perfect information to go with that dipping picture.
here are a couple of older pre paint pictures as well
Cheers Paul.
Edited by user Monday, 26 September 2011 5:59:18 AM(UTC)  | Reason: Not specified
#50 Posted : Monday, 26 September 2011 5:58:44 AM(UTC)
The picture of the HK Monaro in the air is from the Adelaide or Brisbane plant, as these were the only plants to assemble HB bodies.
I am yet to find a Sydney or Melbourne body in HK that was sent to another plant for final assembly.
So my thoughts are Adelaide painted their bodies without the front on and Melbourne and Sydney did, as they were all sent straight onto the vehicle assembly plant.
After talking to Simon, who is based in Adelaide and sees nearly exclusivly Adelaide cars, he has failed to see HKs with a second A. So might I suggest that Adelaide only stamped the second letter on cars they did not complete. This being stamped after the body was painted. Hence the P on the HR being like the HB Chassis numbers I have seen.
As I have already stated the second S was stamped before painting.
I am also yet to see an HK, from any plant, with the chassis number looking like the P on the HR.
The HBs look worse possibly because such a big stamp is used, rather than just one letter.
Warren
#51 Posted : Monday, 26 September 2011 6:46:20 AM(UTC)
The HKTG Garage
hq ss, a photo has been emailed to you. Could you please post it here.
Photo of blue GTS body on forklift is Elizabeth plant.
Photo supplied by Warren which reveals firewall stamping pre paint is taken in Body shop. The operator is seen tending to the lead joins, hence the protective clothing. This photo is pre dipping and is before leaving the Body shop.
Warren, I have done some investigating on the wrecks and bodies in my possession. Most Adelaide built cars I have dont have the second "A" but two so far do. Dont know why some do and some dont. One of the vehicles with the second 'A' is an HK Premier with books sold in Adelaide at United Motors. I remove firewall numbers and tags for reference before disposing of bodies.
I have a Sydney built HK Kingswood from ACT, Melbourne built HG 308 Air/Steer Prem, 5/71 built HG V8 Prem etc. Dirty Davo would have heaps of cuts for reference too. I'll keep looking further into it. I work at Classic and Muscle Restorations in Adelaide now too and there are 8 HK HT Monaros in there awaiting restoration so I'll investigate them further.
#52 Posted : Monday, 26 September 2011 6:54:06 AM(UTC)
The HKTG Garage
Warren, not sure if you noticed but the photo you supplied of the body shows two 'M's stamped one above the other.
#53 Posted : Monday, 26 September 2011 7:35:20 AM(UTC)
Here is Simons picture.
Cheers Paul.
#54 Posted : Monday, 26 September 2011 7:38:51 AM(UTC)
and here is a similar one I have.
#55 Posted : Monday, 26 September 2011 7:43:42 AM(UTC)
Yes I did notice the second M.
I guessed it was Adelaide, as I work behind the Acacia Ridge (Brisbane) plant and there is nothing that looks like the building in the photo.
Warren
petaus Offline
#56 Posted : Monday, 26 September 2011 8:18:35 AM(UTC)
petaus
awesome pics not the blue hk monaro on the fork is missing the boot GTS badge, is it possible that car is a export knock down or goin to perth??? would of been a lot of trouble to match the matellic paint body to guards???
#57 Posted : Monday, 26 September 2011 8:59:29 AM(UTC)
From what I have been told paint and panels came over to WA in huge crates as did engines etc
Then the front panels were painted here off the car and then fitted.
From what I have seen the panels came over in red oxide primer then were painted in the body colour.
At least with the last HQ's guard blackouts were painted after most of the assembly was completed.
Cheers Paul.
#58 Posted : Monday, 26 September 2011 7:33:11 PM(UTC)
That Dandenong HK photo proves that Dandenong stamped their firewall before it was put on the car. If you look at Dandenong chassis numbers they are always very lightly pressed, and the metal around them is not affected plus they are always aligned which means they were stamped when the firewall was horizontal and had something behind it. Pagewood, Elizabeth and Acacia Ridge are very different. On many of the stamps from these 2 x plants a letter or number often drops due to the air tool being used being held vertically whilst the number is stamped. Plus they were given an almighty whack by the metal distortion around the numbers.
I disagree with the second S being stamped before paint Warren, it was stamped by the VAP and on all my Pagewood cars with original paint on the firewall it is stamped after paint.
That blue HK doesn't have its GTS badge probably as the stripes are not painted on yet. This is probably as good evidence as you'll get as to how Elizabeth vehicles were made.
I did have a talk to Ben about this when I was asking him about another matter. He may have a read and put up some ideas here too.
I'm pretty sure Pagewood may have fitted the front subframe before paint at least to GTS's. The reason I say this is GTS's have a gloss firewall. On both my Yellow GTS327 and my mate's Yellow 307 GTS they had no paint between the subframe and the firewall and the chassis number was placed there after paint. All the paint appeared to be done in one go. Other Pagewood cars I have seen have been similar, and they seem to rust in the same place as Dandenong cars. As Simon says the Elizabeth cars are painted separately for front and body and bolted together hence don't rust as bad in that area. One thing Ben reminded me of is South African SUP HT Monaros were all Pagewood assembled and these have body colour boot and engine bay so these probably also had the subframe on when painted. Maybe it was only Monaros done this way at Pagewood? Special Monaro shifts?
#59 Posted : Monday, 26 September 2011 8:23:15 PM(UTC)
Byron,
You will notice that the second M is already on the bare shell, so the second M is stamped by the BAP in Melbourne, so why would the Sydney plant do it at VAP, rather than BAP like Melbourne?
As the build sheet/PSN is already issued before the construction of the shell begins. So they know the VAP before the firewall is put into place. So it could be stamped at VAP or BAP.
I just do not understand how Sydney cars, if stamped after painting, this second S does not appear on many chassis numbers. Yet it is there under the paint. The only way that would happen is if when stamped the paint came away from the metal, the metal retained the indent and the paint went smooth.
If this happened, then the chassis number would HAVE to be stamped before painting as it could lead to no chasis number visible, ie like the second S.
Warren
blameyone Offline
#60 Posted : Monday, 26 September 2011 10:32:48 PM(UTC)
blameyone
A lot of conjecture here but I,m sure that a manufacturing plant the size of this operation would have a set process to follow that may been different from plant to plant but would be set for that plant or assembly line process.and leaving no room for adhoc stampings or guess work. At the same time there is always the occasional error at the time of assemby that will result in guess work 40 years later amongst the likes of fastlane forums. Bob has the scientific side sorted. The area that was stamped would be changed and different to that surrounding it. The structure of the steel has been altered and the steel at the stamp has been exposed where as the area around it has a natural coating to it, and would therefore be less susceptible to oxidisation ie rusting and that the properties of the paint to follow would have changed and the protection different and the rust would therefore show up 1st at the stamp. Could I offer this scenario. Allowing for the occational error. All stamping to the panel was done at the original plant and in the case of HK-T-G at least, the 1st letter following the number indicated that ORIGINAL PLANT and where that car originally came FROM AND the 2nd letter indicated where that partly assembled car had to GO TO or be sent for the final assembly and the 2nd letter was therefor a quick reference with a SIMPLE inspection of the firewall with the second letter indicating where that body was to be shipped whether that be just up the road as in the case of Sydney or to another state altogether. The different configuration of the 2 letters ie in a line or 1 letter above maybe another simple indication to what section of a plant ie suitable for 6 or 8 cylinder or an indication of a particular floorpan and to NOW which assembly line at that particular plant it was to go
Jack
Edited by user Monday, 26 September 2011 10:43:01 PM(UTC)  | Reason: Not specified
Guest (17)
4 Pages<1234>
