Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Passenger side extractor basic fabrication done. A quick check to see they fit correctly then final welding and coating.  [img https://fbcdn-sphotos-f-...487663234266981523_n.jpg][/img]
Almost done. Still some internal welding to do however I gave up for today. Still dealing with this flu virus so I'm not firing on all cylinders. (PUN INTENDED) The desire to be able to fit these pipes with the engine bolted in place has led to the setup you see in the picture. The passenger side setup will fit up in 3 pieces whilst the drivers side is 4. There is also a procedure to fit them that if not followed they won't go in. Luckily I have written it down.
New extractors are back from the coaters and ready to fit..
Joined: 16/04/2014(UTC) Posts: 768  Location: Victoria Thanks: 1 times Was thanked: 49 time(s) in 47 post(s)
Fantastic job Scott. It's looking great, but reeeeaaaaly busy underneath. Did you weld the pipes into the collectors and if so are you concerned about them cracking?
I welded the collectors on mainly to ensure they stayed in place and didn't leak. The pipes run very close to everything under there so can't move around too much. Also welding them on stops leaks. Slip joints are also a bugger to get apart after a lot of use whereas the 2 bolt collectors will always be easy. It's busy underneath because everything that is normally in the engine bay is under the car now and it's all fighting for space. Edited by user Saturday, 9 August 2014 4:48:26 AM(UTC)
| Reason: Not specified
I just need to fit all this now.
Thanks: 8 times Was thanked: 16 time(s) in 14 post(s)
Will you have these on for the EH show at Silverwater, Scott?
That is the plan Keith, see my next posting for progress pics.
quote: Originally posted by greenhj
looking good mate!
THANKS
Hope I can make it to the show so I can have a good look at your car Scott. It's a work of art.
Keith
All I wanted was lighter steering. Well after 6 months and way too much money the EH is finally back together. The Southern Chassis works front end is in and dialed in. The new exhaust fabricated and installed and the new Boyd wheels ready to go. First outing out will be Silverwater Park EH show on 23rd August. Hopefully all goes well.
