28 Pages«<910111213>»
the eh Offline
#201 Posted : Sunday, 29 June 2014 7:30:36 AM(UTC)
the eh
Another job on the TO DO list this weekend is to make and then paint and fit the front brake caliper brackets. The hard part is done with the template being made. I found a piece of 10mm plate to use so it's only a matter of getting it done..
the eh Offline
#202 Posted : Monday, 30 June 2014 4:27:46 AM(UTC)
the eh
the eh Offline
#203 Posted : Sunday, 6 July 2014 5:56:40 AM(UTC)
the eh
Passenger side extractor basic fabrication done. A quick check to see they fit correctly then final welding and coating.
[imghttps://fbcdn-sphotos-f-...487663234266981523_n.jpg][/img]
the eh Offline
#204 Posted : Monday, 7 July 2014 5:50:14 AM(UTC)
the eh
Drivers side basic pipework done. There will need to be some gentle manipulation once the pipes are final welded. Then I have to work out how to make it all fit and be able to be removed easily removed.
the eh Offline
#205 Posted : Saturday, 12 July 2014 6:12:08 AM(UTC)
the eh
Most of the welding done.
the eh Offline
#206 Posted : Sunday, 20 July 2014 7:11:36 AM(UTC)
the eh
New extractors almost finished.
the eh Offline
#207 Posted : Sunday, 27 July 2014 3:43:53 AM(UTC)
the eh
Almost done. Still some internal welding to do however I gave up for today. Still dealing with this flu virus so I'm not firing on all cylinders. (PUN INTENDED) The desire to be able to fit these pipes with the engine bolted in place has led to the setup you see in the picture. The passenger side setup will fit up in 3 pieces whilst the drivers side is 4. There is also a procedure to fit them that if not followed they won't go in. Luckily I have written it down.
the eh Offline
#208 Posted : Monday, 28 July 2014 8:06:45 AM(UTC)
the eh
the eh Offline
#209 Posted : Friday, 8 August 2014 3:14:42 AM(UTC)
the eh
New extractors are back from the coaters and ready to fit..
gm5735 Offline
#210 Posted : Friday, 8 August 2014 6:21:09 AM(UTC)
gm5735
Fantastic job Scott. It's looking great, but reeeeaaaaly busy underneath. Did you weld the pipes into the collectors and if so are you concerned about them cracking?
the eh Offline
#211 Posted : Saturday, 9 August 2014 4:46:52 AM(UTC)
the eh
I welded the collectors on mainly to ensure they stayed in place and didn't leak. The pipes run very close to everything under there so can't move around too much. Also welding them on stops leaks. Slip joints are also a bugger to get apart after a lot of use whereas the 2 bolt collectors will always be easy.
It's busy underneath because everything that is normally in the engine bay is under the car now and it's all fighting for space.
Edited by user Saturday, 9 August 2014 4:48:26 AM(UTC)  | Reason: Not specified
the eh Offline
#212 Posted : Saturday, 9 August 2014 4:49:49 AM(UTC)
the eh
I just need to fit all this now.
greenhj Offline
#213 Posted : Saturday, 9 August 2014 7:06:03 AM(UTC)
greenhj
looking good mate!
KeithA Offline
#214 Posted : Saturday, 9 August 2014 9:02:51 PM(UTC)
KeithA
Will you have these on for the EH show at Silverwater, Scott?
the eh Offline
#215 Posted : Sunday, 10 August 2014 5:41:52 AM(UTC)
the eh
the eh Offline
#216 Posted : Sunday, 10 August 2014 5:43:30 AM(UTC)
the eh
That is the plan Keith, see my next posting for progress pics.
the eh Offline
#217 Posted : Sunday, 10 August 2014 5:44:20 AM(UTC)
the eh
Originally posted by greenhj
looking good mate!
THANKS
KeithA Offline
#218 Posted : Sunday, 10 August 2014 8:19:10 PM(UTC)
KeithA
Hope I can make it to the show so I can have a good look at your car Scott. It's a work of art.
Keith
the eh Offline
#219 Posted : Thursday, 14 August 2014 7:23:21 AM(UTC)
the eh
All I wanted was lighter steering. Well after 6 months and way too much money the EH is finally back together. The Southern Chassis works front end is in and dialed in. The new exhaust fabricated and installed and the new Boyd wheels ready to go. First outing out will be Silverwater Park EH show on 23rd August. Hopefully all goes well.
the eh Offline
#220 Posted : Sunday, 17 August 2014 2:30:17 AM(UTC)
the eh
Test flight successful. There's a rear tyre scrubbing occasionally. Not too worried about that because the old wheels did the same. I thought I had fixed that however by changing the offset on the new wheels slightly. No big deal. The front end worked perfectly. It's a bit bouncier at the moment than the HR setup. However I still haven't had an alignment done and the shocks are set at the comfort/street settings recommended by the manufacturer. I will fiddle with them. I have a slight drip of power steering fluid from the pump and that's it. The front end worked perfectly with NO SCRUBBING at all even around the tight roundabouts around my local streets. I think I got the ride height pretty much spot on first go as well. The bottom of the front crossmember, which is the lowest point in the front end is 115mm off the ground. It could therefore go down 15mm more. I'm leaving it where it is thinking that it may still settle a few mm with use. I'M HAPPY if you haven't guessed. Time to have a coffee and then start cleaning her for next weekend..
Guest (5)
This page was generated in 0.161 seconds.
