gmholdman Offline
#1 Posted : Sunday, 30 October 2011 10:16:39 PM(UTC)
gmholdman
Are hr auto and manual tunnels the same size in a 6 sedan ??? I have had conflicting advice.
Edited by user Monday, 31 October 2011 6:51:08 PM(UTC)  | Reason: Not specified
#2 Posted : Monday, 31 October 2011 2:10:31 AM(UTC)
All HD/HR tunnels are the same regardless of the transmission fitted, but what do you mean by a "6 sedan".
It was the EK, EJ & EH series where the auto had a different (larger) tunnel to the manual.
adam PERTH Offline
#3 Posted : Monday, 31 October 2011 6:29:30 AM(UTC)
adam PERTH
it gets a little fuzzy and confusing, as the powerglide crossmember in HD HR is different to the crash box.
you need a glide crossmember to run an aussie 4 speed.
peter_flane Offline
#4 Posted : Monday, 31 October 2011 7:21:19 AM(UTC)
peter_flane
What about if you want to run a Trimatic in a HR? Will the Powerglide crossmember suit?
#5 Posted : Monday, 31 October 2011 8:25:28 AM(UTC)
Powerglide (6-cyl), Tri-Matic, Hydramatic, Aussie 3-Speed & Aussie 4-Speed all use the same rear mount position.
Aussie 4-Speeds will need some serious cross-member mods because of the shifter, but the others with virtually bolt straight in.
gmholdman Offline
#6 Posted : Monday, 31 October 2011 6:05:12 PM(UTC)
gmholdman
Dr Terry, by "red 6" my mean a 6cyl red motor (not v8) Fitting a trmatic in place of a manual. AL
#7 Posted : Monday, 31 October 2011 11:14:26 PM(UTC)
You actually said :"6 sedan" not " red 6", but I sort of gathered that you meant a 6-cyl anyway. If it was a V8, the tunnel & cross-member etc, may well have been modified as well.
If you're swapping a stock HR manual to auto, you need to use the auto cross-member. The tunnel will accommodate a stock 6-cyl Powerglide, but aTri-Matic has a few protrusions at it top rear, that may require some massaging of the floor frame.
But a Tri-Matic takes the same rear mount & tailshaft as a 6-cyl Powerglide.
gmholdman Offline
#8 Posted : Tuesday, 1 November 2011 2:17:37 AM(UTC)
gmholdman
Dr Terry, thanks for the info. al
