Joined: 2/03/2005(UTC) Posts: 491 ![Australia Australia]() Thanks: 3 times Was thanked: 8 time(s) in 8 post(s)
Are hr auto and manual tunnels the same size in a 6 sedan ??? I have had conflicting advice. Edited by user Monday, 31 October 2011 6:51:08 PM(UTC)
| Reason: Not specified
All HD/HR tunnels are the same regardless of the transmission fitted, but what do you mean by a "6 sedan".
It was the EK, EJ & EH series where the auto had a different (larger) tunnel to the manual.
Dr Terry |
it gets a little fuzzy and confusing, as the powerglide crossmember in HD HR is different to the crash box. you need a glide crossmember to run an aussie 4 speed.
What about if you want to run a Trimatic in a HR? Will the Powerglide crossmember suit? |
Powerglide (6-cyl), Tri-Matic, Hydramatic, Aussie 3-Speed & Aussie 4-Speed all use the same rear mount position.
Aussie 4-Speeds will need some serious cross-member mods because of the shifter, but the others with virtually bolt straight in.
Dr Terry, by "red 6" my mean a 6cyl red motor (not v8) Fitting a trmatic in place of a manual. AL
You actually said :"6 sedan" not " red 6", but I sort of gathered that you meant a 6-cyl anyway. If it was a V8, the tunnel & cross-member etc, may well have been modified as well.
If you're swapping a stock HR manual to auto, you need to use the auto cross-member. The tunnel will accommodate a stock 6-cyl Powerglide, but aTri-Matic has a few protrusions at it top rear, that may require some massaging of the floor frame.
But a Tri-Matic takes the same rear mount & tailshaft as a 6-cyl Powerglide.
Dr Terry |
Dr Terry, thanks for the info. al
