zl296 Offline
#1 Posted : Wednesday, 25 January 2012 5:52:52 AM(UTC)
zl296
puting a hr disc front end into a ej.
have booster,rear wheel cylinders.
ej out rigger to get welded on.
putting red motor...
where do l move the red motor mounts to on the front end.?
picture be great.
l use a eh sump/pick up?
thanks.....dave.
Utility8 Offline
#2 Posted : Wednesday, 25 January 2012 7:04:02 PM(UTC)
Utility8
Although it sounds simplistic, the position for the new mounts need to be where the motor sits right.
If you have access to an EH crossmember out of a car, measurements or a template can be made to accurately position the new engine mounts.
The 4 x mounts for the EH & HR front ends can be used as your references to then locate the engine mounts.
It is possible to re use the HR mounts if you cut them off the HR front end carefully.
Some will suggest to fit front end in the car, then drop the motor in & tack/weld the mounts in place.
This can work, but is a bit hit & miss, particularly without another car to reference engine position from.
Biggest mistake is positioning the mounts too low. Drag link will then hit the sump on full steering lock.
You're right with EH sump, that's what you need for the conversion.
I see you are in Vic., email me if you need more details.
Edited by user Wednesday, 25 January 2012 7:08:19 PM(UTC)  | Reason: Not specified
utility8
zl296 Offline
#3 Posted : Thursday, 26 January 2012 7:43:50 AM(UTC)
zl296
thanks will be in touch...
lytec Offline
#4 Posted : Thursday, 19 April 2012 8:02:45 AM(UTC)
lytec
HEllo there.I know you have to move the mounts and replace the outrigger.But even after checking the pics of some done I am not sure how to measure the correct spot to weld on the red motor mounts at the rear of the hr crossmember.Can anyone help
Utility8 Offline
#5 Posted : Thursday, 19 April 2012 11:30:07 PM(UTC)
Utility8
Yep Craig, I sent an email to you last week which pretty much details the job from start to finish. I didn't hear back, did you receive the email?
If necessary, I can send it again.
utility8
lytec Offline
#6 Posted : Saturday, 21 April 2012 9:12:11 AM(UTC)
lytec
Hello there.Sorry it went to junk mail for some reason.Have got it and replied.Thanks Craig
adam PERTH Offline
#7 Posted : Sunday, 29 April 2012 11:50:02 AM(UTC)
adam PERTH
delicate balance of being high enough for EH sump to clear drag link and still have a good angle at the front uni..
the last few i did years ago i spaced up the gearbox so it was a better angle at the back of the gearbox.
tack weld your mounts with engine lowered with steering on full lock so the drag link is in its highest position.
