ht307munro Offline
#1 Posted : Sunday, 26 February 2012 6:25:14 PM(UTC)
ht307munro
Is the diff housing/axles/brakes etc for a standard HT banjo diff the same as a HT 2.78 LSD banjo diff? Also when you paint the backing plate do you use heat resistant paint or just normal paint?Thanks for your help.
Alex
The HKTG Garage Offline
#2 Posted : Monday, 27 February 2012 4:25:32 AM(UTC)
The HKTG Garage
Yes, the same. Normal paint.
#3 Posted : Monday, 27 February 2012 4:56:05 AM(UTC)
I believe that a 2.78 or 3.08 banjo centre has 2 long bolts at the bottom & the rest short studs, whereas the 3.36 & lower banjos have all short studs & only 1 (short) bolt. The gasket is the same though.
You will need to weld a 5/16-inch UNF nut inside the housing to cater for the extra bolt or use a long bolt as a stud & put a shakeproof washer under its head. A Holden 6 lower alternator bolt will do the job.
