Tom118 Offline
#1 Posted : Thursday, 19 April 2012 3:43:48 AM(UTC)
Tom118
Hi guys. I have a HQ Prem with a factory four speed manual and 3.36:1 LSD.
I want to swap to an auto gearbox and a different diff, but I don't know what to go with. I want it to be quick off the line (traffic lights) but also good for everyday driving. Any suggestions would be great, cheers.
Edited by user Thursday, 19 April 2012 5:58:22 AM(UTC)  | Reason: Not specified
No worries, mate.
#2 Posted : Thursday, 19 April 2012 5:52:26 PM(UTC)
Leave the 3.36:1 centre, will be fine, or change to 3.08.
HQ Sandman Offline
#3 Posted : Thursday, 19 April 2012 9:20:03 PM(UTC)
HQ Sandman
Ive had the 3:55, 3:36 and currently the 3:08.
3:36 is better then the 3:55 and the 3:36 is pretty close to the 3:08 although I find on the highway that it revs lower.
I personally like the 3:08.
#4 Posted : Thursday, 19 April 2012 9:28:44 PM(UTC)
It depends where you are driving for most of the time, city or freeway.
If you drive mostly in the city & as you say you want it "quick off the line", then you will need the 3.36. If you do a lot of freeway or country driving than the 3.08 is the one, but you will lose that low down torque.
Tom118 Offline
#5 Posted : Friday, 20 April 2012 3:15:31 AM(UTC)
Tom118
Alright, thanks alot guys. I'll just stick with this diff then.
Any suggestions on an auto gearbox? I just want something reliable that would go on the 202 without too much hassle. Cheers.
Edited by user Friday, 20 April 2012 10:12:16 AM(UTC)  | Reason: Not specified
No worries, mate.
DaveHT70 Offline
#6 Posted : Friday, 20 April 2012 7:38:13 AM(UTC)
DaveHT70
G'day Tom, I hope you don't think I'm high jacking your post. I have a 3.36 ratio in my diff and I'm interested to know and I believe you may be as well, whether it's worth changing over to the fine spline and if so what are the benefits?
"Reality is an illusion. Albeit a very persistent one"
dirty davo Offline
#7 Posted : Friday, 20 April 2012 8:06:02 AM(UTC)
dirty davo
fine spline is definitely better in bango set up. no probs in hq-z & lh-x set up. but unfortunately no axles to suit hktg or lc lj.
although you can rebracket a n LH-X housing to suit HKTG.
either way its th weakest link & askn for problems if you gunna have higher horsepower
Tom118 Offline
#8 Posted : Friday, 20 April 2012 10:10:54 AM(UTC)
Tom118
I don't mind at all.
I actually didn't have that in mind but now that you mention it, it gets me thinking.
No worries, mate.
#9 Posted : Friday, 20 April 2012 4:37:49 PM(UTC)
It would be cheaper to just find a sedan/coupe/wagon/statesman Salisbury complete diff and tailshaft for a HQ. HK-HG a bit harder than that
DaveHT70 Offline
#10 Posted : Saturday, 21 April 2012 6:15:57 AM(UTC)
DaveHT70
I have a HT wagon and I had to replace an axle in my Banjo diff over a year ago and thought of putting a Salisbury 10 bolt diff on instead. But I found the Salisbury diffs were hard to come by and the ones I did see were $2000 or more, where the Banjo axles were plentiful at around $100 each. I figure I can go through 20 Banjo axles for the price of a Salisbury diff...
Edited by user Saturday, 21 April 2012 6:26:36 AM(UTC)  | Reason: Not specified
HQ Sandman Offline
#11 Posted : Saturday, 21 April 2012 6:54:20 AM(UTC)
HQ Sandman
I am assuming the the HT salisbury is harder to come by. I have bought 3 salsbury diffs (3:36, 3:08 and a LSD 3:08) for my HQ. All were under $100, but I did get a bargain for the LSD though. The other 3:08 was delivered for $60 and is in my shed as a spare. I sold the 3:36 for $90 on ebay.
DaveHT70 Offline
#12 Posted : Saturday, 21 April 2012 5:35:29 PM(UTC)
DaveHT70
Unfortunately I am finding that the prices for the HK, HT & HG Monaro's are pushing up the prices for parts and the Salisbury 10 bolt diffs are a hot item.
DaveHT70 Offline
#13 Posted : Sunday, 22 April 2012 6:04:56 AM(UTC)
DaveHT70
Hey Tom, have you considered a T700 auto transmission?
castellan Offline
#14 Posted : Monday, 23 April 2012 7:16:08 AM(UTC)
castellan
3.36 Ratio and a trimatic should be ok to get ya off the line with a 202 but a 3.08 would slow it down to much of the line.
The trimatic auto should have a heavy duty oil cooler and you could go for a bit higher stall maybe use a 173 converter.
The trimatic auto can be strengthened using the v8 plates.
Tom118 Offline
#15 Posted : Monday, 23 April 2012 9:46:15 AM(UTC)
Tom118
I didn't, isn't that from a Jag though?
I'll try anything as long as it's reliable and I can keep the existing shifter.
No worries, mate.
DaveHT70 Offline
#16 Posted : Monday, 23 April 2012 5:45:50 PM(UTC)
DaveHT70
As far as I'm aware the T700 transmissions are from the VR, VS, VN & VP Commodores.
HQ Sandman Offline
#17 Posted : Monday, 23 April 2012 8:36:18 PM(UTC)
HQ Sandman
Do these bolt straight on and if so, do they also bolt on to a 253?
castellan Offline
#18 Posted : Monday, 23 April 2012 8:48:12 PM(UTC)
castellan
Chev type housing the T700. so to much work to do.
DaveHT70 Offline
#19 Posted : Monday, 23 April 2012 9:06:43 PM(UTC)
DaveHT70
You can buy adaptor units for your engine. The following is a link to a company in Victoria that specialise in automatic transmissions, they have all you need to adapt the T700 to your engine. They also have powerglide's and T400's if you want something other than a T700.
http://www.automatictran...ssion.com.au/extreme.asp
HQ Sandman Offline
#20 Posted : Wednesday, 25 April 2012 4:55:19 AM(UTC)
HQ Sandman
Thanks Dave.
This page was generated in 0.065 seconds.
