#1 Posted : Thursday, 10 May 2012 10:02:43 AM(UTC)
there are 2 pipes which the auto trans oil runs thru to the radiator and back to the transmission.
where the top one goes into the radiator tank it has sprung a water leak, causing the water to spurt out when the engine is running.
there appears to be a large nut around the base of the pipe to the radiator I assume there is a rubber seal or something which keeps the water in.
I rang the holden people to get new seals but they did not have a clue what I was talking about.
Are there seals, how difficult are they to replace, w2here do I get them?
thanks.
#2 Posted : Thursday, 10 May 2012 5:53:21 PM(UTC)
John, these radiators do not have separate service parts, that's why the dealer can't help.
If you have a coolant leak in that spot, my guess is the the plastic tank has a crack in it.
New complete radiators are cheap, shop around, but use the correct coolant otherwise the new one won't last long.
petaus Offline
#3 Posted : Thursday, 10 May 2012 6:39:34 PM(UTC)
petaus
if shoping for a radiatot get a good brand like adrad or something, with radiators you get what you pay for.
#4 Posted : Thursday, 10 May 2012 8:46:35 PM(UTC)
Very true, but I've had several top brand radiators fail, blamed on crook coolant that wasn't.
petaus Offline
#5 Posted : Saturday, 12 May 2012 1:05:03 AM(UTC)
petaus
it seems to be the industry standard on radiators when you want warranty, sorry bud it was stray current caused by bad coolant or some other magical bad earth.
#6 Posted : Saturday, 12 May 2012 1:11:38 AM(UTC)
Yes, been there many times.
#7 Posted : Sunday, 13 May 2012 9:49:30 AM(UTC)
Thanks.
Pulled the radiator today, there are 2 rubber 0 rings one under each tube fitting were fairly easy to remove the old ones with a fine screw driver and a pair of long forceps. replaced with new ones out of my plumber's kit, a little bit small but work, will do again next week when I get to cbc or bsc as the top one still does not seal properly needs to be a bit thinner.
but i suspect there may be a fine crack just next to the tube.
petaus Offline
#8 Posted : Sunday, 13 May 2012 10:05:06 PM(UTC)
petaus
lol i love plumbers they seem to be able to fix anything with there tool kit :-)
