2 Pages<12
Holden1Tonner Offline
#21 Posted : Wednesday, 4 July 2012 5:23:22 AM(UTC)
Holden1Tonner
Thank you so much HK1837 for your reply.
I'm currently running a 205 wide tire (205/70/R14) on a 7" (178mm) wide rim. Going to an 8" rim (203mm) will not change anything as the tire is still 2 mm wider than the rim.
"I killed the Bank"
Andrew Jackson, last words
#22 Posted : Wednesday, 4 July 2012 7:21:26 AM(UTC)
Holden1Tonner
Gents,
I started a new thread on the wheel design - I'd like to have your opinion.
http://www.fastlane.com....topic.asp?TOPIC_ID=28365
Cheers!
"I killed the Bank"
#23 Posted : Wednesday, 4 July 2012 7:25:22 AM(UTC)
Holden1Tonner
Track changes QLD:
"The track of a car or car derivative may be increased
by up to 26mm beyond the maximum specified by
the vehicle manufacturer for the particular model of
vehicle. Off-road passenger vehicles fitted with front
and rear beam axles, may have an increase in track
up to 50mm beyond the maximum specified by
of vehicle."
"I killed the Bank"
#24 Posted : Sunday, 29 July 2012 3:23:12 AM(UTC)
Holden1Tonner
Gent's I've had some more time today to look into this.
QUEENSLAND RULES:
- No limits on rim diameter, only wheel overall diameter
- For a car or car derivative, the maximum tyre width is more than 1.3 times larger than the vehicle manufacturer�s widest optional tyre width.
- Tyre overall diameter must not exceed +15mm or -26mm than the standard tyre for vehicle model
-> Optional original tire and wheel sizes on HQ 1 Tonner/Ute:
org. tyres section aspect overall max. dia min. dia max.section
for HQ Ute width [mm] ratio diameter (+15mm) (-26mm) width (x1.3) [mm]
185SR14 (82) 185 0.82 26.0" (659mm) 26.5" (674mm) 24.9" 240
195SR14 (82) 195 0.82 26.6" (675mm) 27.2" (690mm) 254
F78S14 (78) 201 0.78 27.1" (688mm) 27.7" (703mm) 261
--> wheel diameter for a HQ 1 Tonner in QLD can be 24.9-27.7"
--> max. section width can be 260
-> Tire "BF Goodrich Radial T/A" (Raised White Letters)
tire overall recommended width difference with
size diameter rim width suggested rim width
255/60R15 27.1" 7-9" 77-26 (52 with 8" rim)
215/70R15 26.9" 5.5-7" 75-37 (25 with 7.5" rim)
illegal sizes:
275/60R15 28.0" 7.5-9.5" 85-34 (21 with 10" rim)
295/50R15 26.6" 8-10" 92-41
- The original manufacturer�s front and rear track measurements for a car or car derivative is increased by more than 26 mm
-> HQ wheels have a standard offset of 13-16.5mm, the track per side can only increase by 26/2=13mm, so we have minimum offset of 0mm.
- The tyre width of the narrowest tyre fitted to a vehicle is less than 70 percent of the width of the largest tyre fitted
So the final choice would be:
front: 15x7.5" with 0mm offset (for tire BFG R/T 215/70R15)
rear: 15x9" with 0mm offset (for tire BFG R/T 255/60R15)
Does anyone see any issues with the QLD rules?
Anyway, I'm moving back to South Africa taking car with me..
"I killed the Bank"
2 Pages<12
