Fastlane
Holden Forums
Holden Technical Talk
Replacing WH statesman ignition barrel
Hi, the ignition barrel on my WH stato broke internally today. Just wondering when I replace it will I need a new key for the new barrel and then if so does this mean I'll need to replace the door lock to match so I only have to use the one key? Can you order a new barrel that will match the keys that I have already?
Any help would be good |
1970 HG Panelvan 1971 HQ 1 Tonner 2001 WH Statesman Kawazaki KLX250SF |
Go to a good locksmith - they will code a replacement barrel to suit your existing key. The one near me even has the barrels in stock for VN-VS and VT-VZ. |
Fastlane
Holden Forums
