B_Bartos Offline
#1 Posted : Saturday, 8 September 2012 5:10:13 AM(UTC)
B_Bartos
Hi all, I've finally found the time to start the resto on my 1969 HT Monaro 80737. I am sure this site will be my Savior as the car was stripped 2-3 years ago, and as I'm approximately the same age as the car, my memory aint what it used to be! Having read back through previous posts I can see there are many GURUS willing to give their advice. So to my question, date code on toe of steering column is 7L9, date code on 16.7 ratio steering box is 19F0 about 7 months difference?; non-original steering box? or would this be normal for the era. Reason I ask is, the codes on my 1970 built kingswood sedan are both 6D0 for steering column and steering box. Not that it matters if its a non-original steering box, am just curious is all..
Gunna be a long time staring up at the lid of a box.....
The HKTG Garage Offline
#2 Posted : Saturday, 8 September 2012 9:10:11 AM(UTC)
The HKTG Garage
Yes, you have the wrong steering box
dirty davo Offline
#3 Posted : Saturday, 8 September 2012 9:54:25 AM(UTC)
dirty davo
not often is steering box th same date as column. usually cuppla days, or even a week afterwoods. ALSO, so 'many' date th steering box same as "big nut" on m/cly also.. & this is wrong wrong wrong!! 99% of th time, big nut is (usually) a few days later, as they cant build rome all in one day!! juss nott possible
#4 Posted : Sunday, 9 September 2012 3:21:29 PM(UTC)
You'll find batch dates too, as the boxes weren't built at the assembly plants (I think they were built in Woodville SA?). Pre GTS when the 16.7 boxes were rarely used they can pre-date the car by months. As Davo says dates between parts are often close but not always.
B_Bartos Offline
#5 Posted : Monday, 10 September 2012 12:30:40 AM(UTC)
B_Bartos
Thanks guys. So are there any other date codes on front end of car, sub-frame etc, that I can compare?
dirty davo Offline
#6 Posted : Monday, 10 September 2012 4:35:17 AM(UTC)
dirty davo
on front outrigger of K frame on LHS, should be close to st/box datecode
B_Bartos Offline
#7 Posted : Monday, 10 September 2012 6:54:18 PM(UTC)
B_Bartos
can you give me a hint please DD, vertical face,horizontal? middle ,end? Got a lota grease and dirt to get thru....
ht307munro Offline
#8 Posted : Monday, 10 September 2012 11:08:13 PM(UTC)
ht307munro
From memory vertical face on passenger side.
Alex
Squeak327 Offline
#9 Posted : Monday, 10 September 2012 11:48:21 PM(UTC)
Squeak327
Yes ^^^^^ is correct. Stamped not stencilled, just forward of the elongated hole in the vertical passenger side face and you need to remove the splash pan to see it.
B_Bartos Offline
#10 Posted : Tuesday, 11 September 2012 3:49:03 AM(UTC)
B_Bartos
Thanks guys. Had a quick look, looks like L9D? Will have a closer look tomorrow.
B_Bartos Offline
#11 Posted : Wednesday, 12 September 2012 2:50:42 AM(UTC)
B_Bartos
Had a good look today 12L9D, 12 NOV 1969 D??
dirty davo Offline
#12 Posted : Wednesday, 12 September 2012 8:53:33 AM(UTC)
dirty davo
thats th one mate.
'D' who knows? they all seem to have that, regardless of disc or drum.. maybe all were made in dandenong? who knows..
B_Bartos Offline
#13 Posted : Thursday, 13 September 2012 4:49:36 AM(UTC)
B_Bartos
Thanks for your help guys, next question; Brake Booster, non big nut m/cyl, date code 20G9(20 july 1969)
P66133, VH312 and under this,
Model N/ 1 and under this is stamped
VH305 which has had 5 X's stamped over the top of the VH305. Whats this all about??
#14 Posted : Thursday, 13 September 2012 5:42:20 PM(UTC)
VH305 was the very first of the direct pushrod boosters (i.e. without relay levers) & was soon updated to VH315, aFAIK they are interchangeable.
dirty davo Offline
#15 Posted : Thursday, 13 September 2012 5:53:25 PM(UTC)
dirty davo
P6613 is th code on alloy PBR m/cyl for disc brake. P6612 is for drum
B_Bartos Offline
#16 Posted : Friday, 14 September 2012 4:21:41 AM(UTC)
B_Bartos
So the "x"-ed out VH305 is fairly normal then? Had a look at wiper actuator arms today, BLI on both but on right end mount was BLK, left mount BLI??
