mal6910 Offline
#1 Posted : Monday, 24 September 2012 12:54:11 AM(UTC)
mal6910
Engine number B03665A Cast 21J9(21 9 89)is this a rebuilders number,there is no room at the start of the engine number to stamp another number.Thanks
#2 Posted : Monday, 24 September 2012 3:05:23 AM(UTC)
It isn't a GMH engine number. Looks more like a WB chassis number to me, ie AWB03665A. Most VN engine numbers will be VUxxxxxx with the occasional VE, VK or SU prefix.
mal6910 Offline
#3 Posted : Tuesday, 25 September 2012 2:33:41 AM(UTC)
mal6910
HK1837,i noticed in your profile picture that you have a 1 ton overlander,was it built pre 1980 or 1983 to 1989,the reason i ask is that i have a 11/79 vacationer wagon,the last one built around 1989 for and by the engineer that worked for Arthur.Glove box was signed by Arthur in 2008 as authentic.
#4 Posted : Tuesday, 25 September 2012 4:16:52 AM(UTC)
It was built in July 1978 from a new B06 1-tonner. It was a factory L31 M41 GV4 tonner in Ultra Blue. Had U17 dash but no air or steer, column shift and buckets.
It was number 3 of what Arthur called "series 2" which I believe was just HZ (but included wagon), and "series 1" were HJ and HX but only utes, vans and tonners.
