Todd64eh Offline
#1 Posted : Sunday, 11 November 2012 5:02:40 PM(UTC)
Todd64eh
Hi, sorry if this has already been answered on this forum, but I couldn't find anything...I just bought a 64 EH Holden wagon. I am doing a full resto on it. This is my first restoration project ever and first EH!
I was wondering if someone could help with simple instructions or advice about putting a HR disc brake front end? I know you need to make some mods, but what exactly needs to be done? Any help really appreciated!
#2 Posted : Sunday, 11 November 2012 6:51:33 PM(UTC)
The main 2 modifications needed to fit an HD/HR front crossmember to an EH is swapping the outrigger (front protrusion) from the EH crossmember & moving the engine mount towers rearwards (about 3-inches) so they sit in the same location as on the EH.
It's not rocket science but a bit of commonsense & welding skill is important, I've seen it botched quite often.
Todd64eh Offline
#3 Posted : Sunday, 11 November 2012 10:39:07 PM(UTC)
Todd64eh
Thanks, is it necessary to change the rear end as well? I heard the HR front end is different to the EH rear end therefore the rear should be swapped too?
#4 Posted : Monday, 12 November 2012 12:48:03 AM(UTC)
The rear end can stay. All that needs doing to the rear brakes is to fit the smaller 9/16-inch wheel cylinders & brake shoes to match. These will fit straight onto the existing brake backing plates.
If you were fitting the HD/HR disc brakes to an FX-EK it would be then be preferable to fit the later rear end, as the later rear shoes & cylinders will not fit into the earlier model's brakes.
Todd64eh Offline
#5 Posted : Monday, 12 November 2012 2:33:25 AM(UTC)
Todd64eh
Ok thanks! So I just got to find a hr front end with hr outrigger attached and move the mounts to fit, and throw away the eh outrigger....? Sounds pretty simple really!
#6 Posted : Monday, 12 November 2012 3:55:53 AM(UTC)
NO, the other way around.
You find a complete HD/HR ball-joint front end & remove its outrigger & fit the one off your EH front end. The throw away the old HD/HR outrigger.
The fitting of the mount towers is important, they must be fitted in the same position as on your old EH front crossmember, relative to the chassis rail mount points.
Todd64eh Offline
#7 Posted : Monday, 12 November 2012 4:15:26 AM(UTC)
Todd64eh
Ok thanks so much, got you now... I assume I keep all the ball joint, sway bars, wishbone, all the add on stuff to cross member etc etc of the HR?
Really appreciate your help, for a newbie information like this is so helpful....thanks!
peter_flane Offline
#8 Posted : Monday, 12 November 2012 5:55:15 AM(UTC)
peter_flane
EH sway bar, as it clears the EH outrigger and mounts to the EH chassis rails.
Rare Spares have a change over HR front end available with the mounts and outrigger moved.
If you are a member of one of the EH clubs, another member will usually have jigs to do the conversion for you
Todd64eh Offline
#9 Posted : Monday, 12 November 2012 6:39:42 AM(UTC)
Todd64eh
Thanks, now just got to find a hr front end!
coupe Offline
#10 Posted : Monday, 12 November 2012 7:15:02 AM(UTC)
coupe
Hey Todd I have some here with and without stubs and rotors/calipers, from memory you need the hr draglink also, only problem is I'm in Brissy
Todd64eh Offline
#11 Posted : Monday, 12 November 2012 7:45:37 AM(UTC)
Todd64eh
Thanks, I'm in Port Macquarie NSW, but my bro lives in Brissy and I think he may be coming to Port for Christmas....maybe I can work something out. Do you want to email me prices? [email protected]
Thanks all!
coupe Offline
#12 Posted : Monday, 12 November 2012 8:34:57 AM(UTC)
coupe
I sent you an email mate, cheers
greenhj Offline
#13 Posted : Tuesday, 13 November 2012 4:15:26 AM(UTC)
greenhj
Was thanked: 15 time(s) in 13 post(s)
this is interesting, is it the whole front end (with new bushes etc) or just the bare crossmember portion?
#14 Posted : Tuesday, 13 November 2012 4:43:53 AM(UTC)
You don't need the HD/HR draglink. Even though it is a better design, it fouls the EH sump on full lock because of its shape. If you mount the engine even further rearwards (you'll need to delete the accelerator cross-shaft) this can be overcome, but there's nothing wrong with stock EH linkage, if it's properly set-up.
#15 Posted : Tuesday, 13 November 2012 4:46:48 AM(UTC)
I believe it is sold bare.
It would quite expensive to do as a complete exchange unit, you would need new bushes & ball joints etc etc, fitted adding even more labour costs.
Todd64eh Offline
#16 Posted : Tuesday, 13 November 2012 5:16:45 AM(UTC)
Todd64eh
Hey Coupe, I never received that email, would you please try again? [email protected] thanks.
coupe Offline
#17 Posted : Tuesday, 13 November 2012 5:21:25 AM(UTC)
coupe
Sorry mate, sent it to the wrong email, just sent now, cheers dan
Utility8 Offline
#18 Posted : Wednesday, 14 November 2012 9:02:55 PM(UTC)
Utility8
I have seen many draglinks hit the sump on full lock when a HR front end is fitted to an EH/EJ, it has usually been through incorrect placement of the engine mounts. This can also be attributed by, or exacerbated, by the rear transmission mount being too low.
Accurate positioning of the engine mounts on the HR front end, to replicate the exact position & angle of the original EH mounts, should alleviate the problem of draglink fouling the on the EH sump.
My current EH, fitted with HR frontend including HR draglink, doesn't have this problem. I did take care with mount positions, but only placed them where the original EH would have been using a jig built off the EH frontend. Maybe I was just lucky?
Edited by user Wednesday, 14 November 2012 9:07:16 PM(UTC)  | Reason: Not specified
utility8
Todd64eh Offline
#19 Posted : Thursday, 15 November 2012 6:15:40 AM(UTC)
Todd64eh
Thanks for all your help people, could I ask another question? I know my eh came out with the 179 and 149 motor, I have the 149. Would a 186 bolt straight in without any mods?
HGV8 Offline
#20 Posted : Thursday, 15 November 2012 8:07:09 AM(UTC)
HGV8
Was thanked: 11 time(s) in 10 post(s)
Yes, 186 fits with no modifications.
j.williams
Guest (22)
