David 67HR Offline
#1 Posted : Friday, 15 February 2013 4:24:24 AM(UTC)
David 67HR
Can anyone tell me what the cam grind was on the HR X2 186K engine, also what valve sizes are in the heads?
castellan Offline
#2 Posted : Friday, 15 February 2013 5:04:27 AM(UTC)
castellan
Same as the auto HT-T 186 cam i think.
the valves are the same size as all red 6 cyl.
#3 Posted : Friday, 15 February 2013 6:01:16 AM(UTC)
I'll check my books, but I'm pretty sure the X2/S camshaft had the same cam timing as the stocker, but more lift.
AFAIK the valve sizes were the same size as the stockers also.
David 67HR Offline
#4 Posted : Friday, 15 February 2013 9:39:26 AM(UTC)
David 67HR
If i put a 12 port aluminium yella Terra Head on a 186K block what would be a good cam grind?
#5 Posted : Friday, 15 February 2013 4:55:50 PM(UTC)
Talk to a pro engine builder. It will depend very much on what induction & exhaust you are using, it all has to work in unison as a complete package.
David 67HR Offline
#6 Posted : Friday, 15 February 2013 9:41:26 PM(UTC)
David 67HR
Yes i understand, C.O.M.E ground a cam for my 2000 VTII R8 224/228grind, also put on VY inlet manifold and VCM OTR intake for 350 RWHP
David 67HR Offline
#7 Posted : Friday, 15 February 2013 9:46:27 PM(UTC)
David 67HR
The cost of an Aluminium Head is about $2500 complete with claims of 33% less wait and 50HP compared to stock red 6 head. What HP improvements would a stage 3 yella terra iron head give compared to stock 6 head?
