hello is there any way of telling if my hk prem is a factory v8 or 6?
I've heard you can tell by the speedo cable location?, mine is between the wiper motor and brake booster but lower than the bosster?? is there any other way of telling? any help would be great
I dont know how to bring up the photo but search for "HK ute project" on this site and you will see a photo of a HK V8 firewall with speedo cable hole. Hope this helps
The model number or the first five numbers of your VIN can also tell you if it's a six or eight.
James |
You only have to be in front at the end of the race. |
Thanks: 1 times Was thanked: 243 time(s) in 217 post(s)
James
Not for HK James. Only HT, HG & HQ have separate model numbers for 6 & V8. Dr Terry |
Thanks: 1 times Was thanked: 606 time(s) in 573 post(s)
V9 HK have the speedo cable over below the wiper motor, towards the centre of the firewall. They will still have the 6cyl hole too with a speeod cable grommet in it. |
Ok thanks. I'll keep that in mind. These are the codes I have:
801 - Belmont 6 803 - Monaro / Kingswood 6 804 - Monaro / Kingswood 8 805 - Premier 814 - Brougham 818 - GTS 327
As you say these are also used for HT-HQ.
I haven't shown the ones that didn't reference HK eg 812 - Prem / LS 8.
James |
There is is 04 in HK either James. Only 01, 03, 05, 07, 14 and 18. |
James, do you have a copy of my '60 Years of Holden' book ?
If you do go to pages:- 40, 44, 48 & 55 & all of these codes are listed in table form, along with any optional model packages.
Dr Terry |
I have the 45 years book. My interest is mainly '70s models. |
