#1 Posted : Monday, 15 July 2013 7:57:50 PM(UTC)
What HQ's had the green houndstooth seat inserts in them?
Did it depend on the external colour of the car of was it just an option you could ask for?
The green might look ok in a Barbados green car.
The other question is, why are some HQ's herringbone and others houndstooth, was that optional as well?
Edited by user Wednesday, 17 July 2013 7:00:14 AM(UTC)  | Reason: Not specified
GeeR Offline
#2 Posted : Tuesday, 16 July 2013 8:04:21 PM(UTC)
GeeR
My info might be out of date now, but as a starting point:
1971
'Short grained' Roebuck vinyl
Houndstooth Check inserts in Black / White available with all.
Houndstooth Check inserts in Black / Green available only with Comb. 1813, 1821, 1827, 1828, 1833, 1848, 1849.
1972
Houndstooth Check inserts in Black / Green available only with Comb. 1813, 1823, 1828, 1832, 1838, 1843, 1847.
Plus HQ SS - 10C Black / White Houndstooth inserts, 10D Black / Flax Raydo inserts.
1973
'Long grained' Roadrunner vinyl replaces Roebuck
Houndstooth option replaced:
GTS coupe / GTS sedan with Ranier (aka Herringbone) inserts.
Monaro with Raydo inserts.
LS coupes a different set of cloth insert options again over the years, also changing 1973.
___________________________
WTB:
- HQ-WB(?) bench seat 4-speed shifter
- HQ-WB ute rear window
- HQ-WB standard rims
- HQ-HX coupe front windscreen mouldings
- HQ-HX coupe door mouldings (the stainless one running along top of door exterior)
justgm Offline
#3 Posted : Tuesday, 16 July 2013 8:10:25 PM(UTC)
justgm
Hi , early HQ (S1) July 1971, b/green houndstooth , only GTS and with black vinyl seats , LS had Diamond cloth , Kingswood & Premier Raydo cloth. Is Roebuck like Royal cord cloth ? as this replaced raydo in (S2) premiers & ls monaro ,about August 1973.
#4 Posted : Tuesday, 16 July 2013 10:49:23 PM(UTC)
1971
1972
1973
Thanks Geer,
Actually I screwed up my second question I wrote roebuck but I meant to say herringbone. I'll edit that.
So Ranier and Herringbone are the same thing? I didnt know that.
I was wondering why some cars have herringbone and others houndstooth but you've answered that, although I'm not 100% convinced yet.
I've got a late 74 GTS thats I've owned for 24-years and its original seats were houndstooth before I replaced them about 20-years ago (with houndstooth again), are you sure they were suposed to be Herringbone in 74?
Maybe some Holden plants did their own thing.
Edited by user Tuesday, 16 July 2013 10:53:17 PM(UTC)  | Reason: Not specified
#5 Posted : Wednesday, 17 July 2013 12:27:42 AM(UTC)
If you have ownd the car since 1989 then there is a very good chance that it was retrimmed in cloth houndstoth that was readily availble at that time, but ranier was not. Have seen lots of late HT to HQ Monaros with this cotton houndstooth, I also had it in an LH Torana that I purchased in 1990.
It could not be a plant thing as the seat covers had to be ablt to be replaced, so the trim line had to match what was going in the car. Roebuck & Houndstooth trims start with a 1 or 2 and Longrain & Ranier trims start with a 3. SOoif your 74 Monaro has a trim starting with 1 or 2 i.e. 10Y then it might be a special order. If it starts with 3 then it is longrain vinyl trim and no houndstooth.
#6 Posted : Wednesday, 17 July 2013 4:57:09 AM(UTC)
I'm at work and I dont have the interior code of that car, not sure if it starts with a 1,2 or 3 probably a 3 I guess.
My other car is also a 74 GTS and its got houndstooth as well.
It needs the seats done anyway so I'll go with the correct black long grain & ranier/herringbone.
Body HQ80469 XW8
Trim 1877-30Y 30Y
Paint 568-15827
#7 Posted : Wednesday, 17 July 2013 7:09:05 PM(UTC)
From memory that car you listed has the same cotton houndstooth that I was talking about.
Warren
#8 Posted : Thursday, 18 July 2013 8:05:56 AM(UTC)
Warren
Yeah my green car has some cheap nasty material and poorly made seat covers.
My blue car I always thought was originaly houndstooth but I cant confirm that until I get back to Aus.
