Simmo Offline
#1 Posted : Tuesday, 30 July 2013 8:16:37 AM(UTC)
Simmo
The baffle in my tank has come adrift. It possible did a long while ago. Im about to paint the inside and outside. I dont want to pull it apart, will this be a major problem.
#2 Posted : Tuesday, 30 July 2013 5:52:26 PM(UTC)
I've seen heaps of them where they have been cut and patched to fix this problem.
Chris Day Offline
#3 Posted : Tuesday, 30 July 2013 7:40:11 PM(UTC)
Chris Day
I have repaired a couple before without pulling them apart
Drill out the old spot welds with a qtr drill bit
Using wire, magnets, pry bars or any brilliant idea relocate baffle into position
I then put self tapping screws through the qtr holes I drilled to hold it in place.
Then its a matter of plug welding up the holes
It take patience and a bit of luck but can be done
Chris
Ps Once drained and washed out a good idea is to use exhaust gasses from a running car to quell any petrol fumes
Chris
#4 Posted : Wednesday, 31 July 2013 12:51:53 AM(UTC)
Nitrogen could work too.
