monman71 Offline
#1 Posted : Friday, 16 August 2013 1:55:39 AM(UTC)
monman71
Hi, I'm having a little problem sometime when I turn the ignition on to start on the hz, the light comes on that it is charging but when turning the key over sometimes its dead , I have checked battery terminals, the battery is new, its like the ignition is faulty, is there a relay etc that become warn over time. Thanks
#2 Posted : Friday, 16 August 2013 11:05:58 PM(UTC)
Try looking at the ignition switch or if it is an auto also at the inhibit switch (also the plugs for the inhibit switch at the column or T-bar).
