monman71 Offline
#1 Posted : Friday, 16 August 2013 1:55:39 AM(UTC)
monman71
Hi, I'm having a little problem sometime when I turn the ignition on to start on the hz, the light comes on that it is charging but when turning the key over sometimes its dead , I have checked battery terminals, the battery is new, its like the ignition is faulty, is there a relay etc that become warn over time. Thanks
#2 Posted : Friday, 16 August 2013 11:05:58 PM(UTC)
Was thanked: 603 time(s) in 570 post(s)
Try looking at the ignition switch or if it is an auto also at the inhibit switch (also the plugs for the inhibit switch at the column or T-bar).
This page was generated in 0.017 seconds.
