coupe Offline
#1 Posted : Monday, 26 August 2013 5:50:57 PM(UTC)
coupe
Hi i was wondering if there was a way to tell the differences between these gearboxes from looking at them not pulling them apart
#2 Posted : Monday, 26 August 2013 6:06:55 PM(UTC)
Was thanked: 242 time(s) in 216 post(s)
I assume you are talking about 3-sp boxes, if so, they are considerably different in both appearance & size.
Maybe someone on the forum could post some pics.
coupe Offline
#3 Posted : Monday, 26 August 2013 10:22:36 PM(UTC)
coupe
Yep sorry, 3 speed from crash to synchro as I would like to know if I can just remove my non synchro box from my ej with column shift and a red motor and keep the shift pattern the same with a sychro box, thanks
#4 Posted : Monday, 26 August 2013 10:55:45 PM(UTC)
Unfortunately no, the EJ's column linkage will not work will the 3-sp all-synchro box.
You will need a floor shift conversion to make it work. Also because the all-synchro is a much larger gearbox, you will need some serious floor surgery, tailshafts mods & a conversion cross-member to make it all work. If you're doing all of that, you might as well fit an Aussie 4-sp or Toyota 5-sp.
Utility8 Offline
#5 Posted : Monday, 26 August 2013 10:55:50 PM(UTC)
Utility8
Can be done, but a tricky job.
Bell housing, box size & rear mount are different.
Tailshaft & clutch are also different.
There is a guy on ebay that sells a kit that can do the column shifter though.
Non Synchro.
Later model all synchro.
Edited by user Monday, 26 August 2013 11:00:35 PM(UTC)  | Reason: Not specified
utility8
coupe Offline
#6 Posted : Monday, 26 August 2013 11:25:45 PM(UTC)
coupe
So what would I get the above synchro box from? Also how much floor work is needed? I dont mind chasing the parts if I can get a shifter linkage conversion but I dont want to hack into the floor, thanks utility8 for the pics mate and thanks also Dr Terry
Utility8 Offline
#7 Posted : Tuesday, 27 August 2013 1:27:58 AM(UTC)
Utility8
To get the box to the correct height, unfortunately, you'll need to manipulate the floor. If you've got a factory auto body shell, the floor work is still required, but significantly less....but floor work is still floor work.
utility8
peter_flane Offline
#8 Posted : Tuesday, 27 August 2013 4:22:55 AM(UTC)
peter_flane
It would be easier to fit a Toyota 4 speed with floor shifter than an all synchro 3 speed.
