splitpin69 Offline
#1 Posted : Tuesday, 17 September 2013 5:21:25 AM(UTC)
splitpin69
Hi guys, does anyone know if a manual V8 Kingswood would of left the factory with drum brakes all round, or were they all optioned up with front discs?
gunna be a long time staring at the lid of a box.....
#2 Posted : Tuesday, 17 September 2013 6:17:49 AM(UTC)
Depends on what model and what state. From 1969 NSW had to have disc for V8, and from HG they were standard on V8.
HGV8 Offline
#3 Posted : Tuesday, 17 September 2013 6:55:17 AM(UTC)
HGV8
Was thanked: 11 time(s) in 10 post(s)
I seen a HK Premier wagon, factory V8 with drums on the front, was surprised to learn they were fitted like this. Owner said something about because it had air or power steer can't remember which one, it couldn't be fitted with disc. Don't know how true that is.
j.williams
splitpin69 Offline
#4 Posted : Tuesday, 17 September 2013 7:42:40 AM(UTC)
splitpin69
1969 HT Kingswood Melbourne built.
Edited by user Tuesday, 17 September 2013 7:55:47 AM(UTC)  | Reason: Not specified
#5 Posted : Tuesday, 17 September 2013 4:51:04 PM(UTC)
In early HK, you couldn't order both a/cond & disc brakes together on the 307. You either had discs & no a/cond or a/cond but only drum brakes. It was because the V8's a/cond compressor fouled the brake master cylinder in front of the relay lever booster.
By the time the GTS & Brougham were released this became a serious issue. There were various attempts at altering the brake pipe plumbing to overcome the problem, but eventually they went to the direct pushrod type booster.
AFAIK it wasn't until HG that GM-H finally made disc brakes std for V8s, in all states.
#6 Posted : Tuesday, 17 September 2013 5:36:28 PM(UTC)
I remember seeing a pre Monaro release HK 337 that was very original and heavily optioned (5 litre, auto, discs, air and steer plus lots of other bling). Like Dr Terry says it had a funny master cyl on it with a front hose entry. I can't remember the booster though. I think the car was a late May - early June 1968 build by Ben's estimate.
HGV8 Offline
#7 Posted : Tuesday, 17 September 2013 8:48:29 PM(UTC)
HGV8
Sounds about right Terry, the HK 307 prem with drums had air and steer and was early 68 model. Bit of a stuff up there by GMH by the sounds of it.
So this all explains why the change in the booster setup on HK's?
Edited by user Tuesday, 17 September 2013 8:50:34 PM(UTC)  | Reason: Not specified
j.williams
albyht Offline
#8 Posted : Wednesday, 18 September 2013 4:30:03 AM(UTC)
albyht
My ht is factory v8 and has front disks but I don't know if it was required
This page was generated in 0.094 seconds.
