#1 Posted : Monday, 30 September 2013 8:08:14 AM(UTC)
On the VR auto matic I have to remove the consol but the gear lever knob is in the way. according to my VN manual the surround should lift over the knob but no matter how I twist and turn it it won't come off. what is the trick?
thanks.
#2 Posted : Monday, 30 September 2013 4:01:41 PM(UTC)
Turn the surround 90 degrees around, and then "roll" it up & over the gear knob towards the radio - it will just have enough clearance to do so.
The black strip that fits around the lever & travels up & down with it is the hardest to remove without breaking. You have to be very careful when twisting it just the right way to open up the gap in the side & remove it from around the lever - I find "one up one down" twist of the plastic either side of the gap to be the best way. It's worth practising this at a wrecking yard if you've never done it before.
#3 Posted : Tuesday, 1 October 2013 10:31:02 AM(UTC)
thanks mick i did manage to get it off already its a tight fit.
now its developed a short and keeps blowing the fuse to the instrument lights and the little light in the gearshift thing when i turn the lights on. it just goes on and on doesn't it.
also its difficult to get the consol off as well.
#4 Posted : Tuesday, 1 October 2013 4:05:44 PM(UTC)
Most common cause of an instrument light short in these is the light in the cigarette lighter. The wiring breaks off & earths out on the gear lever plate, or someone has had it apart before & routed it wrong, causing it to earth out once the insulation is worn through.
The other one I often see is when people wire up aftermarket radios & don't use the illumination wire, but fail to insulate it properly.
#5 Posted : Friday, 4 October 2013 11:09:24 AM(UTC)
Well got it all apart without breaking anything. the cigarette lighter light was ok, the problem seems to be in the light to the auto trans consol.
the light goes on and off when wriggled, but does not seem to have any breaks, so is probably in the insulation somewhere. at least it is only the globe goes off now, it has stopped blowing the fuse.
I did move the wiring around so maybe that has moved the fault somewhere else.
