malibu Offline
#1 Posted: : Monday, 24 February 2014 2:54:57 AM(UTC)
malibu
Is It possible to fit triple webers to 179 eh without removing the battery?
AEH.179
colt Offline
#2 Posted : Monday, 24 February 2014 4:16:08 AM(UTC)
colt
It would be one of those compact batteries but it would still be in the way. You have to get rid of the original sheet metal carrier. Don't forget you also have a pressure regulator and fuel block to fit in as well as the fuel lines.
Colin.
malibu Offline
#3 Posted : Monday, 24 February 2014 8:18:31 AM(UTC)
malibu
Colin.
AEH.179
malibu Offline
#4 Posted : Monday, 24 February 2014 8:21:41 AM(UTC)
malibu
so do you think some other carbie system would be better I have a 350 Holley on there at the moment, Would like to dress up the engine some more.
Regards ,Peter.
AEH.179
Utility8 Offline
#5 Posted : Monday, 24 February 2014 9:01:42 AM(UTC)
Utility8
What's your priorities, drivability, economy, wow factor when the bonnet is open?
More importantly, what's your budget?
utility8
zl296 Offline
#6 Posted : Wednesday, 26 February 2014 7:06:11 AM(UTC)
zl296
to much fuel for a red motor...
Premier 350 Offline
#7 Posted : Saturday, 1 March 2014 2:51:06 AM(UTC)
Premier 350
Any particular reason you want to ditch the Holley?
Economy? Performance?
How about a 2 BBL Weber downdraft? As used on the (cough) XE & XF
falCONs
Utility8 Offline
#8 Posted : Saturday, 1 March 2014 2:57:01 AM(UTC)
Utility8
falCONs
Agreed.
utility8
#9 Posted : Saturday, 1 March 2014 4:54:59 AM(UTC)
what would be the pick of the 3? weber varajet or holley 350 for a slightly warm 202 ?
for general useability, economy, streetability?
peter_flane Offline
#10 Posted : Saturday, 1 March 2014 5:37:12 AM(UTC)
peter_flane
The XE Weber works well, as does the Holden X2 setup.
Triple Webers is for an engine that is suited for high RPM power, the cost would be about $10,000 to do the entire carb, engine and drivetrain. Understanding you need new distributor, head, motor, engine rebuild, cam, etc.
