#1 Posted : Monday, 14 April 2014 10:20:26 AM(UTC)
I am thinking of putting VR 205x65x15 wheels/tyres on my stock 202 VK auto.
what effect will this have on the speedo and performance?
thanks
#2 Posted : Monday, 14 April 2014 4:29:40 PM(UTC)
Just work out the tyre diameter and compare to what is standard. It is easy to work out, 205mm is the width. Profile is 65% of the width. So diameter is 205mm x 0.65 x 2 + 15" (15x25.4mm). Do the same for the standard tyres and divide one by the other to see the % difference. You should be able to change the speedo gear to suit as 205/65/15 was a VK standard size from memory.
#3 Posted : Tuesday, 15 April 2014 4:00:03 AM(UTC)
The rolling diameter of standard 14" and 15" are so close that Holden fitted them all with the same speedo gear, so the answer is zero.
Warren
#4 Posted : Tuesday, 15 April 2014 4:04:39 AM(UTC)
Wow so quick and easy thanks guys. just the 205s look so much bigger.
