laurence Offline
#1 Posted : Friday, 15 August 2014 2:08:22 AM(UTC)
laurence
Does anyone know about how they work after a side only accident but both bumpers removed sensors don't work anymore wiring has been checked by a auto electrician and Holden even swapped the module with a new one still do not work they beep when park and reverse are engaged but do not work trying to sort this out with insurance company but they not keen on paying to fix them. They worked right till I took it to repairer any ideas. car is 2006 caprice
#2 Posted : Friday, 15 August 2014 9:19:44 PM(UTC)
WL or WM?
I have a bit of experience with the VE/WM system, but not the earlier ones.
We had a clown back into the front of our VE and drive off - luckily we got the details from a witness, and the numberplate impression left on the bar.... It also makes it easier when they park in the same spot every day at my wife's workplace.
Anyway, it smashed the crap out of one of the front sensors, the bar reo, and washer bottle (yet outward appearance of the bar suggested it was only a light tap). I duly bought all the replacement parts from Holden & fitted them - only to arrive at the same issue you have now.
I found they updated the front sensors on the VE/WM during early production, and the ones they sell as a replacement - which do plug in, aren't compatible with the early VE setup - they beep & do all the right things, but they don't sense any distance or put the graphics on the screen. Putting a 2nd hand early one in place fixed the issue, but they're still a bit hit & miss whether they work or not. Also, since then, the rear ones work intermittently too. I've been over all the plugs & wiring, and everything checks out.
They didn't change any of the sensors when the bars were off?
laurence Offline
#3 Posted : Saturday, 16 August 2014 5:25:32 PM(UTC)
laurence
No the bars were not painted or sensors replaced they worked till I took it for repairs now the console switch flashes all the time and the beeper goes for about 5 seconds when reverse and drive are selected it is a Wl model 2006 model
