made2redline Offline
#1 Posted : Monday, 2 February 2015 10:21:27 PM(UTC)
made2redline
hi follow holden fans, i have a 2004 monaro which is leaking water from either side of the radiator, i think , cant really see, has any one else had this prob from a ls1 cheers darren
#2 Posted : Tuesday, 3 February 2015 5:46:00 AM(UTC)
I recently had a water leak on my VZ LS1, the Driver's side of the radiator was wet, ended up being the radiator cap, thought it was a split tank.
Warren
#3 Posted : Tuesday, 3 February 2015 9:23:18 AM(UTC)
made2redline
Warren
yer ok where is the radiator cap lol cauase it dont have one only fill thru coolant tank
#4 Posted : Wednesday, 4 February 2015 5:05:53 AM(UTC)
Sorry about that VZs have a radiator cap, VY do not.
Warren
#5 Posted : Wednesday, 4 February 2015 6:15:16 AM(UTC)
V2II/III Warren. Wash your mouth out!
#6 Posted : Wednesday, 4 February 2015 6:38:01 AM(UTC)
made2redline
yep your right hk spot on lol
#7 Posted : Wednesday, 4 February 2015 8:27:20 AM(UTC)
made2redline
but thanks guys for your feeddack, thats why this site is good
#8 Posted : Wednesday, 4 February 2015 6:24:57 PM(UTC)
OOh! Picky, Picky.
And some people call me pedantic.
#9 Posted : Wednesday, 4 February 2015 9:37:53 PM(UTC)
Not that picky Terry!
I would have thought people calling VG utes VN, or VU utes VX, or V2 Monaros VX or VY would be one of your pet hates too!
Warren knows better than most hence my in-jest comment.
#10 Posted : Wednesday, 4 February 2015 10:13:34 PM(UTC)
made2redline
its a series 3 guys
#11 Posted : Wednesday, 4 February 2015 10:52:26 PM(UTC)
I realise it was in jest, & you are correct, but my comment was also in jest.
Having said that, the radiator cap thing wasn't unique to the V2, it was common also to VTII, VX, VY, VU, WH, WK etc. etc.
#12 Posted : Thursday, 5 February 2015 5:21:06 AM(UTC)
It is always interesting this stuff, I have a productionline sticker that has VX coupe on it. So why not V2 coupe? Or do some sections of GM-H refer to it as a VX and others a V2.
But its like people calling a Statesman a Holden, a HZ GTS a Monaro etc etc etc. The list just goes on.
Warren
#13 Posted : Thursday, 5 February 2015 5:56:44 AM(UTC)
Is it X as in Calais/CV8 luxury level Warren?
I get what you mean though. I've had Ford w@nkers try to tell me a V2 or VZ Monaro is a Commodore, but they get upset when you tell them Fairmonts and Fairlanes must be Falcons then. I also get how people associate Statesmans as a Holden or a HQ SS or HZ GTS as a Monaro. But a V2 is in no way a VX, or a VY just like a VG isn't a VN or a VU isn't a VX.
gm5735 Offline
#14 Posted : Thursday, 5 February 2015 6:11:14 AM(UTC)
gm5735
The rot did set in early.
"FX Holden" anyone?
#15 Posted : Friday, 6 February 2015 11:42:16 PM(UTC)
made2redline
ok
Edited by user Saturday, 7 February 2015 9:11:45 AM(UTC)  | Reason: Not specified
gm5735 Offline
#16 Posted : Saturday, 7 February 2015 9:32:24 AM(UTC)
gm5735
Any chance it's split one or both tanks? This is quite common.
You can get some dye to add to the coolant to help see the leaks if you don't want to pull the radiator out to check.
Is it using water, and emptying the reservoir bottle and the radiator as well?
#17 Posted : Saturday, 7 February 2015 10:00:26 AM(UTC)
made2redline
hi, yes it does leak both sides, ithought may be a split tank but was hoping a loose connecton
#18 Posted : Saturday, 7 February 2015 11:58:06 AM(UTC)
my vr developed a crack around the the pipe from the gearbox, just on the side of the radiator. it was a bit hard to detect exactly where water was coming from.
