Premier 350 Offline
#1 Posted : Thursday, 16 April 2015 11:17:06 AM(UTC)
Premier 350
Location:: On a build over WWII airfield. Got the .50 cal cases from my driveway to prove it
Apart from the plates welded to the underside, what are the differences between a TH400 cross member & the other ones?
Gear box mount holes in a different position?
Thanks for your help.
Chris
#2 Posted : Thursday, 16 April 2015 5:12:12 PM(UTC)
Slots in a different spot. Ute/van/tonner are narrower too.
Premier 350 Offline
#3 Posted : Thursday, 16 April 2015 11:39:44 PM(UTC)
Premier 350
Any ideas how much narrower? I've just sold mine to a bloke with a one tonner.
Better not bank the money just yet!
Thanks, Byron.
#4 Posted : Thursday, 16 April 2015 11:57:49 PM(UTC)
About 50mm overall. The commercials have boxed rails hence why the crossmember is shorter,
Premier 350 Offline
#5 Posted : Saturday, 18 April 2015 7:28:42 PM(UTC)
Premier 350
Thanks again, Byron. Ended up refunding his money & I learnt something.
#6 Posted : Saturday, 18 April 2015 7:34:17 PM(UTC)
You can turn a sedan/wagon/coupe/Statesman one into a commercial. Just lop the ends off, redrill 4 x holes and weld the captive nuts back on (or just use bolts and nuts). Just lay a commercial one next to it and mark where to cut and where to drill the holes.
This page was generated in 0.083 seconds.
