jayHK69 Offline
#1 Posted : Monday, 27 April 2015 7:10:03 PM(UTC)
jayHK69
on my hk the hand brake cable passes under the gearbox cross member & rubs against it when the hand brake is used.
should there be a pulley or something in this area for the cable to run through ? it has the pulley near the fire wall
jason
ht307munro Offline
#2 Posted : Monday, 27 April 2015 9:27:33 PM(UTC)
ht307munro
Mate mine has a metal "guard" that goes over the gearbox cross member and the cable rubs on that.
Alex
gm5735 Offline
#3 Posted : Tuesday, 28 April 2015 1:33:22 AM(UTC)
gm5735
Jason, the assembly drawings are here:
You can see the wear plate bolted to the bottom of the cross member on the drivers side. The cable contacts this plate and rubs on it by design.
It seems fairly rough to me, but that's how they are. HT/HG are different as the cross member is bolted to extension rails on the subframe and the handbrake cable runs between the floorpan and the cross member.
jayHK69 Offline
#4 Posted : Tuesday, 28 April 2015 7:47:48 AM(UTC)
jayHK69
thanks for the replies & pics,very helpful
looks like it would be easy enough to bend something up
jason
