Jeffro81 Offline
#1 Posted : Thursday, 14 May 2015 8:12:50 PM(UTC)
Jeffro81
Hey Guys,
New to this so bare with me on it.
Just brought a HKTG to muck around with, pulled the front passenger guard off to clean rust and found this spring. Just wondering on its purpose. Ive tried to post a photo.
http://s12.photobucket.c...622_zpsdjteqzli.jpg.html
gm5735 Offline
#2 Posted : Thursday, 14 May 2015 8:53:14 PM(UTC)
gm5735
Hi Jeffro. I can't really tell from your photo, but the only spring that lives in there is about 120mm long, has 15 coils about 25mm in diameter. One end hooks into a hole in the inner fender. The other end hooks into a clip around the brake hose. The spring keeps the brake hose up and out of the way of wheel and suspension components for all combinations steering lock and wheel travel.
blameyone Offline
#3 Posted : Thursday, 14 May 2015 9:07:57 PM(UTC)
blameyone
Hi gm5735, I haven't got one with me to check but from memory I don't think that spring is quite that long.
Jack
#4 Posted : Thursday, 14 May 2015 10:25:51 PM(UTC)
I believe that gm5735 is correct, that is the brake hose spring which all HK/T/Gs had.
The 120 mm length includes the rather long end 'hooks'.
Jeffro81 Offline
#5 Posted : Friday, 15 May 2015 2:30:26 AM(UTC)
Jeffro81
Thanks heaps guys. gm5735 would be spot on as it lines up with the brake line and the measurements seem spot on. Just wanted to check to make sure of what its for as the previous owner took the brakes off the front.
