stkilda.1 Offline
#1 Posted : Saturday, 27 June 2015 10:06:17 PM(UTC)
stkilda.1
Hello, can someone give me some feedback, just recently, my v6 1995 Statesman, just cuts out at when driving the engine light comes on , I wait 3 min the al is fine , it keeps doing this, I have serviced and changed fuel pump and filter, any suggestions will be appreciated.
#2 Posted : Saturday, 27 June 2015 10:44:39 PM(UTC)
It doesn't sound like a fuel problem.
My money would be on either the DFI module or the crank angle sensor. Both moderately cheap to replace.
#3 Posted : Saturday, 27 June 2015 11:18:24 PM(UTC)
Definitely crank sensor or ignition module.
If it's a V6, pour water down the front of the motor (aiming behind the main pulley) and if it starts quicker than 3 minutes wait, then it's definitely the crank sensor, which is the more common failure on the V6.
If it's a V8, try the same water trick on the alloy module behind the air filter box (these are the more common failure on V8s).
When they go flakey, it's usually heat-soak that shows up the problem. Waiting 3 minutes allows it to cool a bit, and come good.
The thermal shock from the cold water normally kicks them back into life sooner if they are on their way out, and helps pinpoint the issue.
stkilda.1 Offline
#4 Posted : Sunday, 28 June 2015 4:37:29 AM(UTC)
stkilda.1
Thanks guys will try the water next times it happens and eliminate sources
